Education Recommend me a chair.
Discussion in 'General' started by Kronos, 14 Jul 2017.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I think i am going to buy or rather have bought for me a half decent chair as I spend a fair bit of time in a day on it. The current one from Staples was okay when new but pretty rubbish now.
    Been looking at a Steelcase Leap v2 from here https://www.2ndhnd.com/search?q=steelcase+leap+v2
    Anyone bought from them and any other recommendations for a chair? I think my budget will have to around the £300 mark hence the second hand market.
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I picked up a Humanscale Freedom recently, very comfy, plenty of recline, keeps you supported however far back you lean. Chap on ebay sells them refurbished for under £200, stock will pop up and disappear depending on availability.
    Downside is it lacks all the 'normal' adjustments leaving only 'set it once' adjustments: seat height, headrest height, seat slide (forward/back), and back height; along with armrest lift/lower. If you have everything else set up properly (proper desk height, proper monitor height, proper keyboard and mouse placement) then it's very comfortable and requires no fiddling. If you don't have everything else set up properly, you cannot compensate with the chair.
    Desk height is the big problem for most, very few desks have a height adjustment and far too many are set way too high for proper ergonomics.
    Vault-Tec likes this.
  3. Vault-Tec
    30 Aug 2015
    Still got mine. I absolutely love it. It's big enough for me too :D
  4. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    Easily solved by being tall, like me :)
  5. Gareth Halfacree
    4 Dec 2007
    Second-hand Herman Miller Aeron. I absolutely love mine.
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Think I need to have the ability to adjust as I have back issues that sometime mean I need to alter back support.
    Edit: Just looked at a video and I am having a change of mind here. Any chance of a link to the Ebay seller.
    A bit weird I know but I really do not like mesh.
  7. Vault-Tec
    30 Aug 2015
  8. Vault-Tec
    30 Aug 2015
  9. edzieba
    14 Jan 2009
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    Anyone know what delivery adds to the price?
  11. Vault-Tec
    30 Aug 2015
    I paid £25 and it came on a pallet. ED - Mine had the armrests etc but I broke the whole mech by lifting myself into the chair to sit hippy lol. I had to bind up the back with paracord to keep the arms up. Mine also has the gel armrests, super squishy :D Since breaking the arms (and then fixing them) I have stopped sitting like a ****. I now sit up properly which this chair has made me do. It's probably the first chair I have ever sat in properly.
  12. BA_13
    BA_13 Minimodder
    2 Sep 2011
    My Girlfriend has a Humanscale Liberty and loves it, but I find it uncomfortable. I have a Herman Miller embody that I think is amazing but my girlfriend isn't so keen on. Both are very good chairs but feel completely different, as such i'd suggest you really need to try out the chair you buy or at least make sure it is cheap and easy to return if you don't get on with it.
  13. Kronos
    Kronos Multimodder
    6 Nov 2009
    Appreciate where you are coming from with your try before you buy advice but I think with the likes of chairs it really does not hold. I bought my last chair from local Staples as I could try the chairs before selecting one. Unfortunately chairs change as you use them and what might have felt comfortable in the beginning might not a year down the line.
    I note that the Humanscale Liberty is mesh which I am not keen on. As for the Herman Miller Embody I am unlikely to find one within my budget.
  14. Vault-Tec
    30 Aug 2015
    with a good chair the dynamics do not change at all. With cheap crap chairs the arse foam goes, the arm foam goes etc etc. With a real chair (like a Miller etc) nothing changes. My Humanscale still feels exactly the same as the first time I sat in it. Then again, specced as it is it was a £1200 chair RRP and it shows.
    Seriously Glen, wait until you get your arse into a real chair. It will make sense then. My last two chairs have been a Herman Miller Sayl and this Humanscale and I will never, ever, buy another cheap chair again.
  15. Kronos
    Kronos Multimodder
    6 Nov 2009
    Phoned a guy on Ebay enquiring after the delivery costs for the Freedom and Edinburgh is too far seemingly.
