Peripherals Recommend me a colour laser printer
Discussion in 'Hardware' started by Arboreal, 29 Jul 2020.
  1. Arboreal
    21 Jan 2011
    My 7 year old trusty Dell C1760nw seems to have given up the ghost.
    I've always run it on 3rd party toner, an only had a couple of niggles.
    It has been awkward for a few weeks as it didn't like the last yellow toner that I bought from it, and despite refreshing the toner etc. it won't print yellow.
    A month ago it came up with the following message on the display:
    "Restart Printer Contact Support if Message returns 09-654"
    I searched about the problem, and cleaned the rear sensors as suggested, but no joy.
    Seems to be a regular problem, and often with no solution. Dell don't give a stuff, as it's out of warranty. No support, buy a new one...
    I'm eyeing up an HP M454DW, and hope it will be OK on 3rd party toner. It's £240 with £120 cashback 'til tomorrow
    The Dell is 390 mm wide and about 420mm long with the loading tray extended.
    I don't have room for anything much bigger, and certainly not one that holds the paper width ways.
    No need for a scanner, just a reasonable Colour Laser that is OK with 3rd party toner.
    What are your thoughts?
  2. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Not a specific model recommendation, but I keep hearing good things about Brother printers (including for the one owned by my dad). Can be more expensive up front than the competition but the inks tend to last longer and be more reasonably priced (at least for inkjets). Worth considering but obviously do some research on any specific models for horror stories.
    Arboreal likes this.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I'd also second Brother. Solidly built, minimal issue with toner refilling with the stock cartridges. Often they will have £100-£150 rebate offers for some of their range. Downside is they are generally a bit on the chonkier end, so may not fit in your available space (the big MFWs definitely won't).
  4. Arboreal
    21 Jan 2011
    Thanks guys, any specific recommendations edz?
  5. teacherboy
    teacherboy Part Carbon/Nylon/Bovine
    29 Jan 2012
    I have one of these - might be a few new ones still in the wild, fantastic thing about it is that rather than buy new toner cratridges, you can refill the original brother ones with toner - it's not the last word in detail for prints but text is fine as are charts etc.
    Toner can be bought from plenty of vendors but I use the guide and products from here
