Portable Recommend me a gaming laptop!
Discussion in 'Hardware' started by ChromeX, 22 May 2012.
  1. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Hi guys, as the title states i'm current looking for a gaming laptop. I'm an officer in the merchant navy and I set off for my first sea tour in august for 4 months, so basically this laptop is more or less my only personal entertainment, so not only is it my tv/dvd player/sound system/work machine it also has to be my gaming system too! I've had a look around and I've got some idea about what I want, but desktops have always been my thing, little out my depth when it comes to laptops.
    I only have one or two considerations, about what I would ideally; everything else I'm willing to compromise. So:
    Ideally 17" screen for watching movies but 15.3 will do
    UNDER £1500, that is the ABSOLUTE maximum I want to pay
    HAS to be from a website with finance options.
    Here's what I'm thinking of so far:
    http://www.scan.co.uk/products/173-...da-gtx570m-gpu-dvdrw-win-7-hp#ProductFeatures
    Recommendations? Ideas?
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Google shows nothing in the UK, so link to this?
  3. Guest-16
    Guest-16 Guest
    G75VW - GTX 670M, Ivy quad core CPU, twin HDD (RAID options available), Full HD display or 3D options, 16GB of mem, 4x USB 3, display port, HDMI, brushed alu keyboard.
    I'll find out where to buy if you want.
    docodine likes this.
  4. Guest-16
    Guest-16 Guest
    Whoever left me this message:
    Best choice? I'm never saying "OTHERS ARE **** BUY THIS NOW". If the OP likes the spec, he can decide by reading reviews and user feedback. If he decides they are negative in areas that are significant to him he can disregard the suggestion. The reply is relevant to the thread, as are other suggestions from others.
  5. KeTZz
    KeTZz Minimodder
    25 Apr 2009
    I was just about to post the link to the laptop you was already looking at :thumb:
  6. Parge
    16 Jul 2010
    Whether or not you get an Asus, Bindi is right, the 6xx series mobile parts from Nvidia are looking astoundingly good, since you are not leaving til August, can you wait til July when there are more on the market.
  7. minimad127
    minimad127 CPC Refugee
    24 Apr 2009
