PSU Recommend me a PSU
Discussion in 'Hardware' started by chrisc1277, 28 Feb 2011.
  1. chrisc1277
    chrisc1277 Minimodder
    12 May 2009
    hello!
    my friends PSU has given up. do you guys have any recommendations for a new one?
    idealy around the 850w and should be modular.
    thanks for any help
  2. adam_bagpuss
    24 Apr 2009
    whats the rig ?
  3. urobulos
    urobulos Minimodder
    13 Apr 2010
    I used the Corsair HX 850. A good PSU though it did blow up after 3 months of use XD. Guess I was unlucky. Though credit to Scan and Corsair on quick replacement.
  4. T2I3M
    T2I3M Minimodder
    13 Mar 2010
    I would also have to say corsair, i am currently using a corsair 750 modular psu :)
  5. Instagib
    Instagib Minimodder
    12 Mar 2010
    What case does he have? If it's an antec 1200/ P183 / P193, these are excellent.
    If not, the XFX BE 850W is a good bet.
    If that was too glitzy, the Corsair HX850 is a safe bet.
    Or if it has to be TRUELY modular, the Seasonic X-850 is pretty awesome (read expensive).
  6. wyx087
    15 Aug 2007
    alternative to Seasonic X-850 is Corsair Ax850. pretty similar unit internally, just a different brand.
  7. chrisc1277
    12 May 2009
    thanks guys for the suggestions.
    Weve been looking at a corsair already and they seem ok. although i quite like the look of the XFX one Instagib has recommended.
    the seasonic looks nice, but to expensive for him id say.
  8. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Seasonic or Corsair AX are the best. The Corsair HX is a close second. The XFX is in third place, but still good.
  9. adam_bagpuss
    24 Apr 2009
    whats the spec of the rig ?
    do you need 850W ?
  10. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    I have a Coolermaster Silent Pro Gold. Probably the cheapest 80Plus Gold PSU available, runs silently and throws out cold air, even at load.
  11. chrisc1277
    12 May 2009
    sorry bagpuss i didnt see your first post.
    hes currently running an overclocked QX6850, 4870x2, 4 gb 1066mhz ram, i think 5 hdds, 5 fans, soundcard, dvd rom, and couple of cathodes.
    its more for future proof, i believe hes wanting to add stuff to it aswell, his power supply dieing has come at the wrong time.
    what are the cooler master psu's like these days? ive got one but its from a few years ago now, mines ok. still powering on.
  12. adam_bagpuss
    24 Apr 2009
    even future proofing you dont need 850W
    with that rig 550W would be fine.
    for single GPU setups you dont need anything more than 650W even for the most beefiest of PSUs
    if he intends to Xfire then 850W would be more appopriate
  13. numanoid
    numanoid Minimodder
    26 Apr 2009
    Tagan bz700w-900w piperock, im waiting to buy one.
  14. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    He's running a 4870x2, so it's effectively crossfire already. 650-750 would probably still be fine.
  15. adam_bagpuss
    24 Apr 2009
    well yeah but its internal Xfire and therefore still only a single card.
    aboslute max power is 75W (PCI-e) + 75W(6pin) + 150W(8pin) = 300W and its certinaly less than that around 225W i believe
    single 650W will be perfectly fine while an 850W will allow for Xfire although personally id never have 2 x 4870X2
