PSU Recommend me a quiet PSU that's cheap
Discussion in 'Hardware' started by Oggyb, 21 Mar 2011.
  1. Oggyb
    Oggyb Mutant
    15 Jun 2010
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  3. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    :duh:
  4. Nowell @ CCL
    Nowell @ CCL CCL Customer Services
    11 May 2010
  5. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Hey Nowell, is that Xigmatek a unit you use in your own builds?
  6. c.ruel
    c.ruel New Member
    9 Jul 2010
    I second fingers66 psu for that price.
  7. Fingers66
    30 Apr 2010
    It was only that price over the weekend, it is now back to £38.34 which is the same price as the Antec EA 380D Green.
  8. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    define cheap?
  9. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
  10. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Many ppl around this forum and others have advised avoiding the Corsair.
    geoboy, under £40 and preferably closer to £30.
  11. geoboy333
    28 Sep 2009
    I have to say I agree with TrashCan. Despite your advice, that is the bets PSU for the budget you've given, plain and simple.
    sorry if thats not what you want to hear but it's the truth
  12. GeorgeStorm
    16 Dec 2008
    I can confirm the Earthwatts is a solid performer, been running for years now in my familes main PC no problems whatsoever.
  13. moody89
    moody89 Member
    19 Feb 2011
    I'm in the same boat as you at the moment mate and am looking for a reliable PSU at around the £30-40 mark for my father's PC. I've heard mixed reviews on the Corsair CX430 so not too sure about this to be honest. The Antec Earthwatts 380W comes with a 3 yera manufacturer's warranty whilst the Corsair only comes with 2 years. There's only a £3 difference between the two so I can see myself opting for the Antec. I may just hang fire and see if it comes up on the Today Only deals in the near future however.
  14. MrTeal
    MrTeal Member
    27 Aug 2010
    I thought they said that it was quite quiet, maybe it was noisy at 80% load and up, but that's got to be pretty normal, and IMO you are unlikely to push it that hard.
    Even though the Antec Earthwatts is more efficient?
  15. geoboy333
    28 Sep 2009
    i dont know about efficiency but i've built three systems with the corsair and i can vouch for reliability.
  16. MrTeal
    MrTeal Member
    27 Aug 2010
    There's no question about it, the Antec Earthwatts is more efficient.
  17. Fingers66
    30 Apr 2010
    I posted elsewhere on this forum about it but the Corsair Builder Series got 9 out of 10 from jonnyguru.
    In addition, they are shortly going to release a v2 of the Builder Series that ARE 80 Plus certified. given they they missed out on being able to be certified (not sure if Corsair bothered once they tested them) by around 1%, they have simply upgraded some of the internal components and have been able to achieve certification.
    Source: http://www.plugloadsolutions.com/80PlusPowerSuppliesDetail.aspx?id=25&type=2 (see bottom of list).
    tldr; I would not hesitate to buy one for a non gaming PC and would consider one for a gaming PC that didn't need too much from the single rail (e.g. a 5770 or equivalent GPU). I only bought the Strider because a) it has reasonable testing results, b) it is going in a web/email/photo only PC using SB on-board GPU only and c) it was £29.99 and it wasn't my budget I was spending.
    If the Strider had been at it's normal £38, I would have bought either the Antec EA 380D or the Corsair CX430.
  18. Oggyb
    Oggyb Mutant
    15 Jun 2010
  19. Fingers66
    30 Apr 2010
  20. Oggyb
    Oggyb Mutant
    15 Jun 2010
    I left the Enermax, and plumped instead for the EarthWatts 380 for £32.39 on Today Only.
