Networks Recommend Me A Router
Discussion in 'Hardware' started by deathtaker27, 28 Jan 2016.
  1. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Hi guys,
    looking for a recommendation on a router for the new house, speeds will be 50 down and 10 up, I would like it to support site 2 site VPNs, but besides that not really fussed, been looking at Drayteks and Cyberoam, any other contenders?
    Also not fussed about wireless, if it has it great, if not I will buy an AP
    Thanks
    DT
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Cyberoam's are firewalls rather than routers.
    What's sort of internet connection is it?
    Do you have static IP's?
    Cisco is always a good choice in my book
  3. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    FTTH, and I will have 1 static IP
    (is FTTH BT or RJ45 normally?)
  4. rollo
    rollo Modder
    16 May 2008
    Depends on budget and what you have to begin with, BThomehub 5 is not a bad router except for wireless transfer speeds.
    To get a better router your looking at spending a decent amount of cash. If your budget is below £100 then the id probably not bother if you have the BT homehub 5 already. Its a free upgrade if you renewel if changing house they will toss it in as a free upgrade.
  5. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Budget is between 100 and 250 ish, home is currently on a draytek but that has to stay here
  6. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
  7. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    We use the Draytek 2860 pretty much exclusively when installing in domestic environments. It ticks all your boxes and is very configurable. Plus you can add Draytek AP900 WAPs to it and configure all of them from the one interface. They're good at handing over too without the need for a Ruckus or whatever.
  8. GiGo
    GiGo was once a nerd.....
    12 May 2002
  9. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
  10. phuzz
    phuzz This is a title
    28 May 2004
    We use the Draytek 2830's at work, and they're rock solid.
    Personally, at home I've got an Asus RT-AC66U running Merlin's firmware and it does everything you want.
    Both Draytek and Asus seem to be pretty good at supporting the firmware on older models, so a tick for both of them there.
