Notebooks Recommend me a small/thin laptop!
Discussion in 'Hardware' started by Byron C, 1 May 2013.
  1. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    Hello all
    Just throwing this out there to see if anyone else has any other recommendations. Not long ago I replaced my ThinkPad X61s laptop with a 2006 Macbook Pro; I thought I wanted a laptop with more power and a nice big screen, but it turns out that I really don't want that at all. Therefore I'm looking to replace my Macbook with another small/light laptop, but this time I think it's time I went for something a little more modern. I've got a few parameters in mind:
    • Screen no smaller than 11" and preferably no larger than 13"/14"
    • Core i3 minimum - ULV vs. standard doesn't necessarily matter, but I'm not interested in anything lower than i3
    • Minimum of 2-3hrs battery life under load - This is critical, I'll spend the majority of my time on battery power; having to be within reach of a wall socket all the time is no better than using a desktop
    • No wider than 25mm (2.5cm) at the widest point - this one is also important to me, the Macbook I have isn't exactly a bulky machine, but my old X61s makes it look like a fat brick (although admittedly a fat brick made of pretty aluminium)
    • Absolute maximum spend of £600 - this instantly rules out most "ultrabook" class devices... I don't want to p*** money away here; if I had more money to spend, I'd save a bit extra and get a Macbook Air.
    I've come up with a few suggestions of my own so far:
    Asus VivoBook S200E - Max of 4GB RAM - the RAM is soldered in (ffs!!!) and there are no additional slots - but it's a very pretty looking machine. And that price includes a Win8 license and a touchscreen...
    Novatech nFinity N1410 - This is supposedly an ultrabook and to be fair the spec looks pretty damn good for the money: Core i5, 8GB RAM, 128GB SSD... The only things I'm not keen on are the glossy screen and the chassis itself: it looks a bit...naff...
    Novatech nFinity N1406 - This looks slightly bulkier than their ultrabooks, but for only £40 more than the N1410 you get a Core i7, GT640M graphics chip and an additional battery in place of an optical drive. Again though it has a glossy screen and a naff-looking chassis.
    At the moment Novatech's N1406 is winning; I plan to pop down there and have a nose at the weekend, as the Cardiff store is about a 5 minute drive from me.
    Anyone else got any recommendations?
  2. suragh
    suragh Derp
    26 Nov 2011
    I have personally used the Vivobook.
    I think they are pretty slick looking, I didn't know it was touch screen until my Boss put his fingers on the screen. :hehe:
    It's a pretty fast laptop & I would be my first choice for a thin laptop!
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    You got rid of your X61s you mad! lol!
    Once you go thinkpad it's hard to go back; having said that, that N1406 looks to right on the money for performance/value. I've been eyeing up what's out there and nothing has caught my eye yet.
    I use Blender which has GPU enabled rendering but only really supports CUDA at the moment, so any device I purchase must therefore take advantage of nvidia cuda, and it's thin on the ground out there.
    Also I run Ubuntu, and despite AMD drivers getting better, Nvidia still wins under linux which makes the idea of steam of linux whilst on the move very interesting ;)
  4. Byron C
    12 Apr 2002
    Cool, good to have feedback from someone who's actually used one.
    Yes, quite mad, it seems... I did consider another ThinkPad, but with the requirements I have it was starting to get into the "if you have to ask then you can't afford it" price range. The X1 Carbon would be nice though :D.
    The only other reservation I have with any of the machines I listed is that they're all 1366*768 resolution - it's not a great deal more than the 1024*768 that my X61s had... But to get higher res you can easily add another hundred quid :sigh:
    The handy thing with Novatech is that they're one of the few retailers to offer a laptop without the OS license. They will supply Windows drivers, but you'd be on your own when it comes to Linux; not that this would put off a Linux user though :)
  5. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    Things that seem to inexplicably increase the price of laptops:
    Laptops supplied with 4/6 GB RAM (6 GB seriously?) should be abolished, there's no excuse. 8 GB sticks can be had for £35.
    A full fat SSD. Who wants a 1TB hard drive on a cheap laptop? I'm not gonna be putting my media library on it or installing lots of games. An £80 128 GB SSD would be 10 times better than a £60 1TB HD for me.
    Rant over, will keep an eye on this thread as I'm looking for a similar thing. I keep drooling over the Yoga 11S that should be released soon.
  6. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Looking at the previous posts, I've got a couple of reservations.
    Unless you're going for used, its going to be hard/impossible to find a laptop that has:
    High res screen, 8gb ram, thin, light and fairly powerful.
    Theres a (one) reason why the MacBook Airs are expensive and its because it fills most of the above specs :D
    This for example is £750 (obv over budget)
    http://www.ebay.co.uk/itm/Apple-Mac...omputing_Apple_Laptops_ET&hash=item2a2c51a2dc
    Fills most of your needs.
  7. Byron C
    12 Apr 2002
    8GB RAM isn't necessarily a requirement, RAM is a cheap upgrade (£30 for an 8GB DDR3 SO-DIMM). Neither is an SSD an absolute requirement; I can always upgrade to a larger SSD in my desktop (it's pretty damn full already) and donate the current SSD, which is no slouch, to a laptop - assuming of course that said laptop accepts standard SATA and not mSATA, which might be a big assumption.
    My problem with the RAM in the VivoBook isn't it's only 4GB, it's that the RAM is soldered in and there are no expansion slots. That's just wrong.
