Build Advice Recommend me a triple 24" gaming pc set up.
Discussion in 'Hardware' started by rainbowbridge, 11 Jul 2011.
  1. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Final build
    1x GPU purchased
    GeForce GTX 580 DS SC
    http://www.scan.co.uk/products/1536...gpu-797mhz-shader-1594mhz-512-cores-dvi-mhdmi
    £395.50 Inc VAT
    Case purchased
    Corsair Obsidian Series 650D Black Mid Tower Case with Side Window w/o PSU
    http://www.scan.co.uk/products/cors...r-case-with-sata-dock-and-side-window-w-o-psu
    £129.18 Inc VAT
    System Board purchased
    Asus P8Z68-V PRO Intel Z68 S1155 Motherboard
    http://www.scan.co.uk/products/asus...-(x16)-ddr3-2200(oc)-sata-6gb-s-raid-atx-hdmi
    £148.42 Inc VAT
    CPU: purchased
    Intel CPU Core i5 2500K Unlocked Sandy Bridge Quad Core Processor OEM
    http://www.scan.co.uk/products/inte...-quad-core-33ghz-gpu-850mhz-6mb-cache-95w-oem
    £159.78 Inc VAT
    Ram: purchased
    Corsair Memory Vengeance Black 16GB DDR3 1600 MHz CAS 9 XMP Dual Channel Desktop Sandybridge Ready
    http://www.scan.co.uk/products/16gb...c3-12800-(1600)-non-ecc-cas-9-9-9-24-xmp-150v
    £134.59 Inc VAT
    Corsair CMPSU-1200AXUK Professional Series Gold AX1200 1200W Modular Power Supply purchased
    http://www.scan.co.uk/products/1200...s-gold-90-eff-sli-crossfire-eps-12v-120mm-fan
    £208.94 Inc VAT
    SSD:
    OCZ Technology 120GB Vertex 3 MAX IOPS SSD purchased
    http://www.scan.co.uk/products/120g...6gb-s-ssd-read-550mb-s-write-500mb-s-75k-iops
    £246.34 Inc VAT
    Storage:
    Already have 2x250GB Sata II drives.
    Cooling
    Corsair H80 Hydro Series High Performance CPU Cooler purchased
    £75.36 Inc VAT
    Headphones:
    Sennheiser PC 360 Gaming Headset with MIC purchased
    £127.30 Inc VAT
    Parts already have
    DVD/BlueRay,Already have a CD/DVD Writer,Keyboard Mouse,Already have Razor Arctosa, Logitech G9,X-fi Fatality.Widows 7 64,Headphones HD515,
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You never stated what your budget is, although I'm assuming it to be big :p
    By the way, as a start, you don't need a RAM cooler...
  3. rainbowbridge
    26 Apr 2009
    Budget say is £1.5k to £2.5k.
    I worked 73hours last week... plus im doing ok online.
    Ive got used to screens in a quad cube shape so three 24" side to side is going to be strange as I pop winodws and full screen you tubes up top.
    Is there any thing coming down the pipe so to speak that should make me hold of on any key componet? When is the next series of Gpu out
    Edit: As suggestions come along in this thread ill update the first post, that seems to be a good idea as would a total created at the bottom.
  4. Bloody_Pete
    11 Aug 2008
    Well, skt 2011 and the new gen of GPU are ment to be out in the next few months I think. The endless cycle of computing...
    Personally I'd wait as BT are doing the new buyers guide this week, I'd take all of the premium system spec but add a beafier GPU. AMD are preferred at you can run tripple screens from one card...
    Also, consider portrait screens, that's what interests me personally, as you get a more compact but super high res screen then...
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    Hmm. You'll definitely be looking at getting at least two GPUs for SLI/Crossfire if you want to play games on high, ideally three. I'm assuming the screens are at least 1080p, so 2GB or more is desirable. Which means:
    Two 6970s or two 2GB 6950s: AMD cards are reported to have awful air cooling when sandwiched together, so spacing out two is the best for air cooling
    Two or three 3GB 580s: Three rear exhaust 580s together is noisy but manageable - but VERY expensive. Two 580s can be spaced out but cost almost as much as three 6970s.
  6. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    The OCZ vertex 3 is better than the corsair one (driver issues sorted) and isn't the H100 now available at scan. Even if it wasn't there wouldn't be much point buying a H80 for the sake of waiting a week :)
  7. Elton
    23 Jan 2009
    Go with petey's suggestion, multi monitor setups are extremely VRAM intensive.
  8. rainbowbridge
    26 Apr 2009
    Unable to source the 700d, had enough of Corsair not being able to provide the products they list as available.. going to be dropping a number of their products from this build in protest :blah:
    Pleased that the premium Player July 2011 is available and will be taking some parts ideas fromt this.
  9. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
  10. fdbh96
    29 May 2011
    Don't know if you want to watercool but isn't the 600t better at air-cooling and quieter. And IMHO the White version looks sweet! :thumb
  11. rainbowbridge
    26 Apr 2009
    Just made some major changes to the build,
    I have been thinking about the CPU and I might as well just get the Intel Core i7 2600K Unlocked, money is not that much of an issue (although its going to hurt when I buy the gtx590).
    Ive gone for the gtx590 as it has triple screen support of the bat, if I need to add a second or third unit further down the road I can do, Ive tried to remain sensible on the SSD front keeping it at 128gb saving some money im sure office can install to a normal drive.
    Bit tech and also 3dgamman off you tube lay praise on the SilverStone FT02B, so this will be the base.
    Since I have a spare quad screen card I may get the PC together excluding the GPU so I have the system built and come bf3 release date or sooner I can ship a GPU in with a meaty 850watter ready to power it or them (2x590).
    Id like to get the H100 cooler but its not available.
  12. rainbowbridge
    26 Apr 2009
    there is the 650 but there is possiblity im going to be putting two hot cards in one box so better to get a proper full tower case here.
  13. thetrashcanman
    18 Nov 2010
    IMHO H100/H70 are a bit of a waste of money, the best air coolers can keep up with them and for the price of the H100 you can get a decent watercooling kit with everything you need and would give you much better CPU temps. Also I don't even think the H100 has been released yet has it?
    Oh and you will need more than 850Watts to power 2 GTX 590'S (if you ever wanted to do that in the future). secondly unless your doing video encoding or something like that i7 2600k is a waste of money, even if you have got it to spend.
  14. Bloody_Pete
    11 Aug 2008
    He says as he chooses a FT02B :p My Elysium makes it look tiny...
  15. rainbowbridge
    26 Apr 2009
    CPU update to i5 2500K, PSU at 1Kw level.
    Could the Corsair Obsidian 650D Mid Tower Case house this kind of pc with these parts in them?
    If we dont go with the SilverStone FT02B (recommended in this months prem player pc..) what else do we look at here.
    I had a H70 cooler before and it was impressive so I was thinking about getting another unit, I think the H100 is out in the states?
  16. thetrashcanman
    18 Nov 2010
    need to change your sig Pete ;D
    the 650D would be fine for your setup, unless you want to water cool in the future, and yes I would say 1Kw, 950W minimum, Enermax Revolution 1050W? or Corsair HX 1000w
  17. donok
    donok Every Little Helps .....
    16 Feb 2011
    thats not the 650D. thats a picture of the 700D.
    dont think you could get 2-3 gpus in a midi case aka 650D
  18. thetrashcanman
    18 Nov 2010
    of course you can, just depend on which board he picks and the slot layout of said board
  19. donok
    16 Feb 2011
    well for triple 24" gaming you'd need a board capable of 2-3 sli/xfire
    and in sandybridge that means either asus extreme maximus or gigabyte ud7
  20. thetrashcanman
    18 Nov 2010
    top bit is true, the bottom bit, half right,
    Yes those boards do Xfire/Sli but so do a host of others
    P8P67 Pro M for example, not a very expensive board but is xfire/sli capable, and I've just realised are you talking about boards that only have full x16 bandwith with an nf200 chip or something? 8x/8x for Xfire/Sli is still fine for cards, the only performance decrease you may see between x16/x16 vs 8x/8x would be in synthetic benchmarks
