Peripherals Recommend me a...
Discussion in 'Hardware' started by meandmymouth, 17 Sep 2011.
  1. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    USB controller!
    I want one for racing games because quite frankly, using the keyboard for racing games isn't all that fun for me.
    My budget is to spend as little as possible, I suppose £20 at most.
    Suggestions?
  2. longweight
    7 May 2011
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    The Saitek ones are pretty decent, they come in PS or Xbox360 flavours as well :thumb:
    Edit: This one, or this one.
    Or you could use a 360 pad, but I prefer the Saitek ones lol
  4. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    xbox pad
  5. drjaydee
    drjaydee What's a Dremel?
    1 Sep 2009
    a standard wired xbox controller works on PCs, u need an adaptor to use the wireless ones though :/
  6. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Yes, yes I do mean gaming pad! I apologise for my lack of correct terminology, I am a n00b.
    I'm not all that keen on the xbox one, but I could get used to it.
  7. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    I got ninja'd there by 3 of you, rugby is distracting me!
  8. noizdaemon666
    15 Jun 2010
    Saitek one I suggested which looks like a PS pad maybe? And damnit man, surely you know you can't multitask like that lol
  9. longweight
    7 May 2011
    It's the cheapest and probably the best....
  10. doggeh
    doggeh What's a Dremel?
    27 Apr 2009
    I have an XBOX 360 pad and it's awesome. I'd happily recommend it over anything else.
  11. iknowgungfu
    iknowgungfu Minimodder
    28 Aug 2011
    As a long time console gamer aswell as PC gamer I have never felt more comfortable witha controller than the 360 pad. The size fits very comfortably in the hands and the buttons are perfectly placed.
    Also, in some games e.g. Just Cause 2 the game automatically detects that an Xbox pad is being used and sets up the controls for you. I don't know if this happens with other pads but it was a nice surprise when I installed JC2 a while back.
  12. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Hmmm, looks like I will be going for the xbox 360 pad. I must admit, at some point in the future I wouldn't mind a 360 console (please don't hurt me!) especially with xbox live coming to the PC and already being on WP7, which I may also switch too.
  13. GoodBytes
    20 Jan 2007
    XBox 360 controller is my recommendation. I have 2 of them.
    The wired one, is great because the wire is SUPER long. And yes, it ends with a normal PC USB plug, no hack or tricks. Just plug-it in, and Vista/Win7 will take it no problem. If you are on XP (or bought the wireless one), you need to use the provided disk.
  14. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    I'm on Windows 7 so looks like it should be nice and easy
  15. GoodBytes
    20 Jan 2007
    Oh if you get the wireless one: you need to buy the PC version, which is more expensive, as you need the wireless receiver.
    Again, and to be clear: nothing is needed for the wired version.
