Displays Recommend me an All In One (£500ish budget)
Discussion in 'Hardware' started by fuus, 10 Feb 2020.
  1. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
  2. GeorgeK
    18 Sep 2010
    Maybe a refurbished model from laptopsdirect might get you what you want for closer to your budget? This perhaps for £520
    https://www.laptopsdirect.co.uk/ref...0h-8gb-1tb-256gb-rx-ve-a1-7dz60ea/version.asp
    Has a Ryzen 5 3550H, 8GB RAM, 256GB SSD + 1TB HDD. Short warranty only though
  3. nimbu
    nimbu Modder
    28 Nov 2002
    Check out the dell outlet.
    The sites a little bad but you can find bargains.
    www.dell.co.uk/outlet
    You can order from both the home and the work side. Personally I'd stick with the business oriented models. (Have 2 27" ones for my parents for over 3 years, both have been solid)
  4. fuus
    4 Dec 2010
    Cheers for the links, will investigate
  5. nimbu
    nimbu Modder
    28 Nov 2002
    Forgot to mention, it would appear that sock refreshes at 11am and 4pm ish on week days
  6. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    I love me a refreshed sock. Can't wear them twice... ;)
    Vault-Tec likes this.
  7. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Don't rule out an Intel NUC mounted onto a monitor with a VESA bracket, gives you the option of upgrading both the PC and monitor later. The price would also be cheaper.
