Other Recommend ... pruning shears
Discussion in 'General' started by silk186, 26 Jun 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    With lockdown and a 3-year-old, I feel it's time to fight back against nature and reclaim our back yard. It's not a bit yard so I don't need big clippers. I'm looking for a pair of pruning shears that will cut through anything and is under £20.
    I borrowed my neighbour's clippers and did the bulk of the work, but I don't want to keep troubling her.
  2. Pete J
    Pete J Employed scum
    28 Sep 2009
    I bought 'FELCO Model 2 Secateurs' off Amazon after some recommendations here. They are £47, but are worth it! A lovely smooth action, designed to last and can cut through exceptionally thick branches (I think my record is 2cm diameter).
  3. silk186
    silk186 Derp
    1 Dec 2014
    I saw these recommended in another thread, but hard to justify given my small "garden", which would mostly consist of cutting the crap that grows over the fence.
  4. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Can I be 'that guy' and recommend a pruning saw instead of shears or secateurs.
    Blaupunkt do a decent one that's less than £20 and will go through absolutely anything. Or you can go mad and get a Silky Zubat, but be warned once you own one it becomes addictive.
  5. silk186
    silk186 Derp
    1 Dec 2014
    I've certainly used one before and they are great for pruning trees. My trouble is nothing so sturdy that I would need to saw through.
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Mr_Mistoffelees likes this.
  7. Cheapskate
    13 May 2007
    Heavier duty has been important to me. You want something like this. Note the stoppers to keep your knuckles from clapping together. The extensions also give you leverage to cut anything that fits in the jaw. When the bin fills up you can use these to chop down the contents to mulch and fit more trash.
    -Guy that's had a bunch of bent and broken shears given back to him after loaning them out.
    -This is probably closer to what you want. I noticed the Fiscars version is one of the ones I had returned bent. They are kinda flimsy.
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
  9. silk186
    silk186 Derp
    1 Dec 2014
    That looks like too much fun.
  10. silk186
    silk186 Derp
    1 Dec 2014
    As my garden is pretty small, and I'm happy with something I can snip with one hand and toss the veg in a sac. As an added benefit, I can store a small pair inside, reducing the risk of rusting.
  11. Cheapskate
    13 May 2007
    Then in that case I only suggest you find a pair that doesn't insist on locking every time you squeeze them shut.
  12. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Does such a pair exist? I am excluding the ones where the lock breaks after two uses and thus are permanently open.
  13. silk186
    silk186 Derp
    1 Dec 2014
    hmmm, I forgot about that "feature".
  14. Cheapskate
    13 May 2007
    @Dr. Coin -In my experience, the lock breaks after 2 uses and starts doing what I said above. :lol:
    Also: The people you loan them to will ALWAYS try to cut wire/chain link fence with them.
  15. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    I would use a pair of side cutters/wire cutters. They work just as well as any pruners.
    enbydee likes this.
  16. Dr. Coin
    13 Sep 2013
    The red mist is slowly rising....
