Other Recommend remote support software
Discussion in 'Software' started by dancingbear84, 22 Jun 2015.
  1. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Can anyone suggest some remote support software, ideally self hosted not cloud based, doesn't cost a fortune, and works with Mac and windows?
    Looked at isl, team viewer, log me in etc but not really right for the situation.
  2. TheMadDutchDude
    23 Aug 2013
    Why aren't they right for the situation? What don't they do that you need them to do?
  3. dancingbear84
    16 Oct 2010
    We are looking to have something that we can host ourselves, not cloud based
    Sent from my Nexus 6 using Tapatalk
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Ammyy admin? Old but still works I believe. We use Go To Assist at work and it's pretty good.
  5. dancingbear84
    16 Oct 2010
    Thanks pookie, I tried ammyy but a lot of av picks it up as a threat,
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    screenconnect is one of the best, you can host it on your own VPS or AWS instance too.
  7. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    I use netsupport manager its a per machine license but you buy as many as you need with a minimum of 2 licenses, cost me about £52 inc vat
    it has a server for secure connection part to it as well(its fairly straight forward to setup)
    I should point out this is not a subscription based service either, so no yearly renewals, once you buy them they are yours forever
  8. Addie
    Addie What's a Dremel?
    9 Jan 2009
    I have no idea on the pricing, it's probably something absured though, but BOMGAR has been the best remote support application I've used, we had it deployed on ~1000 client sites which made life so much easier than those we didn't have it on.
  9. RichCreedy
    24 Apr 2009
    bomgar is good, but try a four figure sum for cost
  10. dancingbear84
    16 Oct 2010
    Thanks guys. I had a look at screen connect it looks pretty good, I'll take a look at netsupport manager too.
    I'll take a look at bomgar but if it is a 4 figure cost I'll be out
  11. saspro
    saspro IT monkey
    23 Apr 2009
    Probably a lot cheaper that the £600k Kaseya's cost me
