Small Form Factor Recommend some micro ATX socket 939 PCI mobos
Discussion in 'Hardware' started by JonDixon, 15 Nov 2005.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Hi,
    Im looking at replacing my shuttle with another self build SFF based on a micro atx motherboard.
    I have seenthe Foxconn NF4K8MC-EKRS which meets my requirements (PCIe, socket 939 accepting X2 chips).
    Anyone know of any others? I'd like to at least have to choose between 2.
    Thanks for any help
  2. Thomas3D
    Thomas3D What's a Dremel?
    11 Feb 2005
    i use a BIOSTAR TForce6100-939, running on on board Geforce6100 untill i get a PCIe video card, i like it so far...you might not need the onboard video though.
    New egg search for 939 pcie matx boards
  3. JonDixon
    12 Mar 2002
    Thanks for the info, any others anyone?
  4. mickey123
    mickey123 What's a Dremel?
    25 Aug 2005
    Hello Jon
    I too am after a Micro ATX mother board
    It must be PCIe compatable for a 7800GT and run my AMD venice 939.
    Can anyone recomend the options open to Jon and I?
    Mickey
  5. nimbu
    nimbu Modder
    28 Nov 2002
    I have one of those foxconns somewhere, nought wrong with it, just dont expect any kinda overclocking......
    There are some "better" Asus one out or to be launched soon.
    Nims
  6. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    don't get the foxconn 939 board. the lack of v-dimm adjustment will limit ram choices.
  7. M@tt
    M@tt What's a Dremel?
    12 Feb 2003
    I have heard great things about the BIOSTAR TForce6100-939 as an overclockers board and I'm buying one for that reason not the fact it's a mATX board oh and that they are cheap (ish)
  8. JonDixon
    12 Mar 2002
    Thanks for adding.
    Except Ive spent all my money now on scalextric.
  9. DynaMode
    DynaMode What's a Dremel?
    13 Aug 2003
    The biostar mobo is great!
  10. Altron
    Altron Minimodder
    12 Dec 2002
    I use a MSI K8NGM2-FID. It's decent, the things that I don't like though:
    Has VGA and DVI ports, but the DVI is DVI-D (works with DVI TVs and LCDs, but not with DVI>VGA adaptor) and there isn't dual monitor support. Why they didn't just put in a DVI-I is beyond me. The BIOS is annoying for booting. You can only boot from one hard drive (In the boot order it just says "hard drive", then below you pick which hard drive) and one CD-ROM. Can be annoying in some scenarios. The ports go PCIe1, PCIe16, PCI, PCI, so it's not too great if you have a big video card heatsink and want to run two PCI cards. PCIe16, PCIe1, PCI, PCI would probably be better at the moment due to lack of PCIe1 cards, but I suppose the way it is now will be the best for upgradability, as there should be some PCIe1 cards soon, and you'll be able to have as big a video card heatsink as you want without interfering with the PCIe1 slot.
    Otherwise, excellent board. For dual channel, make sure one stick is in the green slot and the other is in the purple adjacent to it. Mine supported X2 chips right off the bat without a BIOS flash.
  11. genesisofthesith
    genesisofthesith complete spanner
    4 Dec 2004
    So the 6100/6150 series seems to be the chipset to go for, is there much difference in the gpu speed/feature set?
  12. genesisofthesith
    4 Dec 2004
    Also, i've got a rather large waterblock,n would any of these motherboards cause any problems?
  13. M@tt
    12 Feb 2003
    I have an XP120 on my BIOSTAR TForce6100-939, which fitted without issue.
  14. grungedead
    grungedead Minimodder
    8 Dec 2005
    try looking at the asus a8v vm
    it uses the 6150 chipset and had hd out on the board...
    you can get it from overclockers.co.uk for about 64~ iirc
  15. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I've heard (on some of the HTPC forums) that a few people have had problems with both the Abit & Gigabyte 6150 mobos.
    The recommendation I keep hearing is for the MSI K8NGM2-FID which costs about £60-£65, and provides VGA/DVI onboard,
    & composite/S-Video & component video outputs via a header.
    (Needless to say, this is on my HTPC upgrade wishlist!)
  16. genesisofthesith
    4 Dec 2004
    http://www.newegg.com/Product/Product.asp?Item=N82E16813157085
    What about this mATX board, seems to be getting rave reviews in socket 754 and 939 packages. Is there a real downside to it? I'll be using a 3700+ san diego so the limiting HTT shouldn't be a problem should it (even though it appears to go to 300fsb)
  17. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
  18. Smoove910
    Smoove910 What's a Dremel?
    27 Feb 2006
    Go with the Biostar board. I have an Opteron 148 on it @ 2.9ghz no probs!!!
    If you have any questions, feel free to ask...
    Check out my pics:
    This is all shoved into an Aspire X-QPack.
  19. genesisofthesith
    4 Dec 2004
    Well the tforce looks like it's going to get the nod, shame they couldn't release a 6150/430 version.
    Smoove, what sort of temps is your system running at?
  20. Smoove910
    27 Feb 2006
    Typically I idle at sub-30 degrees. Usually hovers at 28-29 degrees Celsius and gets up to the low 40's under load. However, if I open the window next to the case, I can get it to idle at 20c :)
    I would go with the BIOSTAR board if you are wanting to buy now. If you can wait a while I believe EVGA will be releasing a SFF board that is able to do SLI. (That would be sweet!). Also, I have heard through the grapevine that DFI is supposed to release an enthusiast SFF board. I don't know if it's going to have the NVidia chipset, but I wouldn't get anything else besides an NVidia chipset.
    Good luck and feel free to ask any other questions.
    Thanks
