A/V Recommendations for a new mp3 player
Discussion in 'Hardware' started by ozstrike, 1 Nov 2006.
  1. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Well my music collection has finally gotten too big to fit on my beloved Iriver H320, so I'm looking around for a new one.
    First of all, let me make this clear: I don't want an iPod
    Now that's sorted, let me list what I want from it.
    Would like it to have a decent battery life.
    Needs to be 30+GB
    Would like it to work as a mass storage device (tis useful for transferring files etc)
    Maybe a colour screen, I like the screen on my H320.
    Now the alternative to buying a new one is to get a new drive for my Iriver. I can get a 30GB one, or I think 40GB ones that will fit into my iriver will be available sometime in the near future.
    Anybody have any suggestions/recommendations?
  2. orb
    orb satisfying.
    23 Dec 2003
    Microsoft Zune?
  3. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    If only winamp made a Portable mp3 player.
    edit: added word: portable
  4. orb
    orb satisfying.
    23 Dec 2003
    Yeah, it would be bloated, need lots of plugins to actually play diffrent file types and to make it sound good, and look like ****.
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    a creative zen?
  6. Guest-16
    Guest-16 Guest
    Sansa e270: small, decent screen and playback, bit fiddly to use and has a drag and drop interface! WOO!
    Creative Zen: custom software and I had to RMA my old one twice. Generally cheap and decent quality playback though.
    There are others but this is all Ive used.
  7. specofdust
    specofdust Banned
    26 Feb 2005
    Sansa, that's the name I've been trying to think of each time I see this thread. Havn't got one, but from the reviews I've read the Sansas are great players for a great price, look into them!
  8. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Depends on where he lives tbh.
  9. Der Me!$ter
    Der Me!$ter What's a Dremel?
    14 Sep 2002
    IAudio (Cowon) X5 60GB ***! This player has the best sound quality I have ever had on a portable mp3 player and supports quite a lot of formats including flac and ogg. There is almost no white noise, even my Shure e5s which buzz quite a bit using an iriver ihp120 or iPod 5.5. Other than that it has a color screen and does not need any additional software to transfer files. It is built like a rock (aluminum casing) and also has video playback, which is not all too great on the small screen but I don't use that feature anyway.
  10. ozstrike
    19 Sep 2004
    The cowon looks great, but it is quite expensive. Looks like a more polished version of my Iriver. How is the battery life?
    See the problem with the Zune is, I get the feeling I might fill up to 30GB quite quickly, and then I'll be stuck again.
    Creative only appear to make 20GB players (or that's all I can find), and the Sansa is far too small.
  11. Der Me!$ter
    14 Sep 2002
    I have only had my player for around a month and did not measure the battery life span yet, but it is probably somewhere around what iAudiophile.net wrote:
    The only downside I have noticed yet is that you are unable to sort your music using ID3 tags (although it is possible to display them). You can, however, install Rockbox to fix that problem, which will unfortunately void your warranty.
  12. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    *cough*
    Hmm your right it looks rubbish, and we all know WMP is really better.
    :worried:
    And FYI "25-Oct-2006: Winamp 5.31 ships with FLAC support"
  13. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    dude. toshiba gigabeat S. check it out. they look sexy, have some fairly good reviews and as long as you can find some good video conversion software you have video too (only plays wmv)
  14. <A88>
    <A88> Trust the Computer
    10 Jan 2004
  15. orb
    orb satisfying.
    23 Dec 2003
    Yeah, find an mp3 player with a totally customizable shape :p
  16. <A88>
    10 Jan 2004
    Easy- get any one you like and cover it in play-dough.
    <A88>
  17. samkiller42
    25 Apr 2006
