A/V Recommended 19" LCDs
Discussion in 'Hardware' started by acidfire, 4 Sep 2005.
  1. acidfire
    acidfire What's a Dremel?
    11 May 2004
    Alright, so, what I need right now is a recommendation for a 19" lcd, 8ms or lower for about $500 CAD. I'm lookin to pick up four (dual 7800gtx's are great ;)) for a variety of reasons. Right now I'm looking at the ACER AL1951B 19":
    Size/Type:19" TFT LCD
    Native Resolution:1280 x 1024
    Contrast Ratio:700:1
    Horizontal Viewing Angle:150°
    Vertical Viewing Angle:135°
    Audio:Two integrated 1.5W speakers
    Signal Connectors:VGA (analog D-sub)/DVI-D (digital)
    Chassis Color:Silver/black
    Pixel Pitch:0.294mm
    Brightness (typical):400 cd/m2
    Response Time (typical):6ms
    Colors Supported:Up to 16.7 million
    any one use this lcd?
  2. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    Just a general question here but why 19"... to me 19" doesn't seem to be a good because:
    1. They use the same resolution as 17" screen. True the actual screen is bigger, but the desktop 'real estate' so to speak isn't any bigger for a premium in price, which brings me onto point 2...
    2. For a bit more cash, you can get 20" screens, which are slightly larger in size as well as offering increase desktop real estate as resolutions are often considerably larger. And since you are running dual 7800s, my guess is that they can handle it.
    Personally, I would recommend a dell widescreen 20" TFT... but that's not what you are looking for so i'm not being very helpful am I!
    I'll let someone else with 19" experience do the rest of the talking...!
  3. Lucy2005
    Lucy2005 What's a Dremel?
    25 Jun 2004
    Hi acidfire, i too am looking at a 19 inch tft and after much reading and pricing i have come to the conclusion of this;
    LG L1980Q
    anyhoo hope that helps :thumb:
  4. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    what about the viewsonicvx924
