Recommended CPU Cooler 1055t AMD
Discussion in 'CCL Computers' started by Reddax, 24 Aug 2012.
  1. Reddax
    Reddax What's a Dremel?
    29 Jul 2012
    I'm looking for a decent CPU Cooler for my AMD 1055t cpu as the current stock fan gets pretty noisy at full load. Any suggestions? :)
    Thanks
  2. cookie! nom nom
    cookie! nom nom Minimodder
    27 Apr 2012
    what price? do you overclock? is noise a problem? what case have you got?
  3. Reddax
    29 Jul 2012
    Prince up to and including around £50. I was planning on overclocking my 1055T a little bit perhaps but not too bothered about doing so. I have the DF-85 Antec case. As long as it's not too noisy I'm not too bothered, as the 7 case fans will probably cover it anyway.
  4. cookie! nom nom
    27 Apr 2012
    NH-D14 Dual Radiator and Fan Quiet CPU Cooler comes at £61 but its one of the best for crazy overclocks. if your not going to go for high numbers and care about looks the
    Cool IT Systems ECO II ALC CPU Cooler is the same as h60 (the not the best for cooling but not bad) or just get Cooler Master Hyper 212 EVO CPU Cooler RR-212E-16PK-R1 for good cooling with low cost.
    ccl dont have the best choices on coolers.
