Networks Recommended desktop wireless card?
Discussion in 'Hardware' started by Jimmy6, 8 Sep 2011.
  1. Jimmy6
    Jimmy6 What's a Dremel?
    19 Jun 2011
    Hi all,
    I need to stick a wireless card into my desktop because I can't get an ethernet cable into where I will be working for the next few months.
    I know little about the subject - does anyone have any recommendations? Is it best to get a PCI card, or are external USB adapters just as good? If it helps, I have an ASUS P5Q deluxe.
    Cheers,
    Jimmy
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    get a homeplug! TP-link make good cheap ones. Also known as powerLAN
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
  4. knarF
    knarF Noob
    25 May 2011
    Would a 200mbps powerline, like this one be better than a 300 mbps PCI wifi card?
    Will they also work with any router, i've have mine for about 5 or 6 years now, so pretty old.
    The PCi cards seem a lot cheaper, but i'd rather spend an extra £20 and get a better connection. My router isn't too far away from where the PC will be, but there's a floor in the way.
  5. noizdaemon666
    15 Jun 2010
    Yeah, I think the homeplugs are better in that they drop less packets and obviously you aren't depending on thin air to provide your connection. And obviously there'd be no discernible real world difference in speeds either.
    Hadn't realised homeplugs were so cheap, I'd definitely give them a go.
    Oh, also you don't have to have a wireless network then, so less chance of people stealing your interwebz :thumb:
  6. Jimmy6
    19 Jun 2011
    Sorry people - I should have been clearer in my original post. Where I work I have no phone socket or means to connect one, therefore I can't get "regular" broadband. There is a good wireless signal from a 3rd party company that costs approx £10pm for unlimited use, so I have to go wifi for the foreseeable future.
    I like the idea of a pci card, but really only want the internet for web-browsing and downloading the occasional game/movie, so I wouldn't consider myself a power user.
  7. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Would your suggested card work with this ?
    http://www.amazon.co.uk/TP-Link-TL-...top-Antenna/dp/B001PSB582/ref=wl_mb_hu_m_3_dp
  8. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    i was running one of THESE in my HTPC for a while before i replaced the PC. it was fast enough to stream multimedia over LAN and internet and was overall pretty snappy. the external antenna is a very nice feature which also gives you the option to upgrade later on if need be.
    plus, its only $12!
