Graphics Recommended graphics card for Athlon X2 system?
Discussion in 'Hardware' started by dejv, 22 Dec 2009.
  1. dejv
    dejv What's a Dremel?
    22 Dec 2009
    Hi,
    my ATi 2900xt decided to die on me ... so had to go back to my old nvidia 6800gs :/
    any one reccomand a graphic card that goes with my current pc and will not have a bottleneck?
    below is my current pc setup
    Cpu : DualCore AMD Athlon 64 X2, 2000 MHz (10 x 200) 3800+
    Mobo DFI LANPARTY UT nF4 Ultra-D
    Motherboard Chipset nVIDIA nForce4, AMD Hammer
    Gfx :NVIDIA GeForce 6800 GS (256 MB) (overclocked)
    Hdd : WDC 320GB 7200 RPM 16MB Cache
    Ram :2048 MB
    - DIMM3: Kingston K 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
    - DIMM4: Corsair Value Select VS1GB400C3 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
    Psu :Hiper 600w
  2. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Do we have a budget to work with?
  3. subby
    subby Me...just like you...only better
    5 May 2009
    a good budget card would be something like the 4850 or if you can stretch to a decent amount of money the 1GIG 4870
    depends on what you want to do with the card....Crysis-esq games or just things like text based footy manager games???
  4. dejv
    22 Dec 2009
    prefebbly around £120
  5. dejv
    22 Dec 2009
    currently im playing x-men origins, but will also try and play The Saboteur
    im asking to check which is the best graphic card to buy since my cpu is a bit old and will have a bottleneck
  6. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
  7. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    I would look at the ATI HD 4890, 5770 or (as already suggested) Nvidia Geforce GTX 260 (but 216 and not 192), however I would think that your CPU will be the bottleneck for any of these graphic cards, especially if it is @ stock clocks...
    ________
    Recall wellbutrin
  8. dejv
    22 Dec 2009
    never overclocked my cpu but i dont think that ill get some good results because of my ram.
    when overclocking what temps must they not exceed ? for the cpu,motherboard and vga
  9. Elton
    23 Jan 2009
    60C
  10. Krikkit
    21 Jan 2003
    What a crime - SLi-D and no OC... Shameful! :p
  11. dejv
    22 Dec 2009
    changed fsb...to 210 and currently cpu is @2100mhz
    if i increase more pc will become unstable
    anyone knows a good overclocking guide?
  12. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    NF4 chipsets are epic on a DFI board, however they get very toasty and i killed mine with a 8800GTS installed, as it covered the fan.
    And maybe the fact that it was pushing 320mhz FSB.... :D
  13. dejv
    22 Dec 2009
    couldnt you place the vga in the other pci and it wouldnt cover the fan ?
    also ... anyone knows about an overclocking guide ?
  14. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    I have the same CPU and mine is running at 2350Mhz with a slight overvolt under a Freezer 7 Pro. I've also got 4 PC3200 DIMMs and they're all coping fine. Bit of a boost from stock.
    As for the GPU, I'd go 260 with your requirements, but your core hardware will be a bottleneck for just about anything bar a 4350 tbh.
  15. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    I'd say the 4650/9600GT will do you fine, a 4770 if you want, no need to spend anymore
    If you want to spend more, get the 5770, DX11, cooler and quieter than GPUs around the same price
  16. Burnout21
    9 Sep 2005
    At the time i was using the PCI slots, so wasn't an option.
