Graphics Recommended graphics card for right now
Discussion in 'Hardware' started by Soniclord, 28 Jul 2011.
  1. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    True, definitely only flash an unlocked BIOS, and even then the shaders only account for a few % difference, so I'm not crying that mine didn't unlock. It still OCs like a champ though and got past 6970 clocks.
  2. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Have you not tried running the game with FRAPS turned on so you can monitor whether you are getting an acceptable framerate? Reason I ask is it could turn out you're running it fine it's just the game/drivers have microstutter issues that no one can be arsed to fix. Example: Napoleon and Empire total war campaign map with an AMD card, even at 60FPS microstutter like a female dog on the campaign map when panning the camera.
  3. Soniclord
    Soniclord What's a Dremel?
    14 Feb 2011
    No. I use GPU-Z to monitor the temperature when it's in game and when I exit the game I go to GPU-Z and click show highest reading and it's never much higher than 63 degrees celsius. Obviously dependant on the game I play it can be higher but I've never seen temps above 75 degrees celsius.
    The one I mentioned in my first post :read:
    Alice Madness Returns.
    It's definitely not a heat issue, and what you say about Fallout 3/Oblivion both those games play fine with no issues for me. The only game not playing without stutter is Alice Madness Returns. I'll have a look for a patch for the game but don't think there is one. My gfx drivers are up to date.
    I'm using an Enermax Revolution 850W PSU so definitely more than enough power to supply everything I have.
    I'll try fraps the next time I play it, see what it tells me. :D
  4. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    You could choose a 2GB GTX 560ti. I have one, it works a treat.
  5. Lord Xeb
    Lord Xeb Derka Derpa Derka Derp
    7 Jan 2010
    560Ti but also what CPU do you ahve?
  6. Soniclord
    14 Feb 2011
    It's a Core i7 860 @ stock 2.8 ghz
  7. Soniclord
    14 Feb 2011
    Well going to be buying my new card soonish I think, so anyone looking for a cheapish card to replace their existing aging beast check my sig. I'm not going to be using it so money towards my new card is always welcomed :D
  8. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    if u can find a Hd 6950 2gb you might be able to unlock it to a Hd 6970 .... :)
  9. murraynt
    murraynt Modder
    6 Jun 2009
    If his PSU can handle a 275 then it will laugh at a 560 GTX and would even take a 570 GTX without kicking up much fuss.
    I would be looking at a 6950 myself, but it looks like this is more to do with a bug than lack of gfx power.
  10. Soniclord
    14 Feb 2011
    Definitely can handle the 275 lol, it's an Enermax Revolution 850+ :D
    You mean the upgrade bug? lol.
    Seriously it's just so I can take advantage of Direct X 11 etc. Which I can't currently do.
  11. KASxxWill
    KASxxWill What's a Dremel?
    1 Aug 2011
    For £200,
    My friend has a GTX 560 Ti, which is a little cheaper than price range.
  12. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    I would try to diagnose the jerky frame rate first.
    Use performance monitor and GPU-Z to see if either the GPU or CPU is maxed. If the game has poor multi- threading support maybe it is maxing one core and leaving the others un-used.
    If GPU-Z is not showing the GPU load or VRAM at 100% you have a different problem and it is not your card.
    After this it is time to start checking drivers - video, sound, chipset etc. A clean video driver install is often a solution. When I say clean I mean using Driver Cleaner and the reg cleaner from CC Cleaner for a 100% clean install.
    Also use FRAPS to look at the FPS. If it is above 60fps most of the time and has only periodic slow downs then again it is probably not the GPU at fault.
    I went from a GTX 260 to a GTX 570 and it is about twice as fast. A 275 to a 260 TI would be a nice upgrade.
    Personally I would try to find the money for a 270 or at least a 260 TI with double RAM for future proofing. Crysis 2 and Shogun 2 have already maxed out my 1.3 gig VRAM at 1680 x 1050.
    Good luck.
  13. aNuclearPidgeon
    aNuclearPidgeon Minimodder
    3 Mar 2011
    WHAT?!??! Where is this product?!?!? I coulda saved a lotta money instead of getting a 580GTX TFIII due to its awesome cooler :mad:
  14. Bede
    Bede Minimodder
    30 Sep 2007
    LOL! Scan sent me mine, but I'd be very happy with that 580, I wish I had the money for that card :D
  15. aNuclearPidgeon
    3 Mar 2011
  16. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    It is called the N560GTX-Ti Hawk on the MSI global website but it is not listed on the UK website. It is listed on the MSI EU website though.
    I can't find any reputable UK based retailers selling it but Pixmania do - they are France based so hence the EU tie-in.
    http://www.pixmania.co.uk/uk/uk/9786090/art/msi/geforce-gtx-560-ti-hawk-1.html
  17. Teelzebub
    27 Nov 2009
  18. Bede
    Bede Minimodder
    30 Sep 2007
