Recommended HSF for...
Discussion in 'Hardware' started by cderalow, 29 Apr 2002.
  1. cderalow
    cderalow bondage master!
    23 Jan 2002
    AMD Athlon 1.3GHz, mATX board, no mounting holes (so no Alpha), not a ton of space for mounting (desktop case)
    was looking at the smaller Alpha (6035) with a decent 60mm fan, the Swiftech MCXC370 with something besides the Delta, TT Volcano 7 with the temp controlled fan
    any others? teh swiftech seems expensive to me, but i've heard good things about them
  2. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Think the volcano might be a bit tall....anyway, wouldn't want one on my lugs....
    PAL6035 is my choice...
  3. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    If you don't intend to OC much and want a cheap hsf, the Taisol 760 is pretty good :)
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    they are pretty good as i have one on my second pc and it gets good chip temps considering it is sitting inside a case that could be used as an oven
  5. cderalow
    23 Jan 2002
    on a desktop case thats never going to move... lugs aren't the issue
  6. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Maybe not....but I still wouldn't buy the TT...
  7. KevinOwns
    13 Jan 2002
    Just the knowledge that it could break off is enough for me not to want it. Admit it, you must hit your comp once in a great while. Imagine smacking it and the hsf falls off =\
  8. cderalow
    23 Jan 2002
    wouldn't be hitting a $200 cooler master case thats for sure
  9. KevinOwns
    13 Jan 2002
    Heh, I would probably hit it whenever something was being stupid =\
    (The best way to show a program or hardware it is being dumb is by being a moron yourself)
  10. cderalow
    23 Jan 2002
    as far as its concerned... the only hardware that would be a problem would be sound & video, have a nic in it for purpose of interfacing & remote access (i love XP)... its going to be an expensive part of my hi-fi... going to use it as MP3/divx/extra dvd player
