hi all im currently looking for a 120mm case fan with a blue or white LED could anyone recommend me of any decent LED fans? i like the look of this one but im not sure what its like http://www.scan.co.uk/products/120mm-enermax-tbvegas-duo-case-fan-double-color-redandblue-led-twister-bearing-detachable-blades
I use 2 120mm Akasa's in my 600T on the top, for exhaust. Seem to shift enough air for me and light up the interior really well. If your going for performance I probably wouldn't reccomend them, but their fine for day to day use.
Not bad, is it intake or outtake? You can get the Silverstone Air Penetrator with Red LEDs if its washing air over your GPU or something.
IDK if you can get them where you are but I'm digging Xigmatek fans right now. They are quiet and pump a ton of air.
yea i forgot to mention its an outake fan on the rear of my case, im currently using the standard fan that come with the case. i just wanted one with a LED and performs
I have a Phobya 120mm Red LED fan as my outtake at the back, is quiet and shifts a reasonable amount of air.
i like the look of these 2 but i cant decide which one http://www.scan.co.uk/products/120mm-enermax-uccl12-cluster-twister-fan-(mbt)-veri-speed-white-led-(on-off)-inc-rubber-a-v-plugs http://www.xigmatek.com/product.php?productid=77
I've heard all sorts of nice things about the cluster, and it's what the T.B. Silence fans I mentioned are modeled after. So I can nigh-guarantee you the Cluster will be great.
