PSU Recommended PSU List - Listed On First Page
Discussion in 'Hardware' started by Moyo2k, 22 Aug 2009.
  1. TraumaticHug
    TraumaticHug What's a Dremel?
    23 Apr 2011
    @Moyo2k (+ contributors)
    I just wanted to thank you for this list!
    I had been hovering between splurging on the Antec Truepower 750w or going for the more budget-realistic (but less-good) OCZ ModXstream 700w. This list brought the XFX Black Edition 750W to my attention and it seems to be a damn good PSU at a price I could (kinda) afford.
    (also, I found it on ebuyer for £83.. yay for Google Shopping!)
  2. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    i have a 1050w aopen psu running my overclocked i7 and 2 ati5850's, its not a well known make, but it has never let me down
  3. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Shouldn't this be updated a bit? Seems a tad old, is Moyo2k still updating it and if not should someone not take over the reigns?
  4. xxxsonic1971
    5 Dec 2010
    just been reading about psu's on here, can anyone tell me if AOPEN 1050watt psu's are any good? will i need to replace it for something higher quality?
  5. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    tbh I'm not as regular as I use to be so if someone would like to take over im fine, scrap the thread and make a new one
  6. Smellyhead
    Smellyhead Minimodder
    29 Jun 2011
    What's the best PSU to pick up for ~£80.
    My system will be i5 2500k which will be overclocked and probably only 1 GPU, maybe a 5850 or 6950. Depending on what I can get.
  7. Haawkz
    Haawkz What's a Dremel?
    30 Jul 2011
    Thanks for this, was able to finish my build in my budget.
  8. Hixxy
    Hixxy What's a Dremel?
    22 Jun 2010
  9. amppatel
    amppatel What's a Dremel?
    25 Aug 2011
    Thanks, this really helps with my new build
  10. tonschk
    tonschk Minimodder
    31 Jul 2008
    I dont agree too much with the list at the first post of this thread, why you think enermax is nearly always the best ?, enermax as far as I am aware offer only multiple +12 V. rails.
  11. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    List needs updating, recommend changes and nominations
  12. S1W1
    S1W1 Minimodder
    25 Mar 2011
    I would nominate the Corsair TX750 V2 for budget 701-800w category. It's £83 on Amazon UK at the moment.
    I just bought the XFX Black edition 750W from the list and absolutely love it.
    I would cetainly nominate the XFX 850w Black edition PSU for the budget 801-900w category- it's £95 on Amazon UK and is made by Seasonic (please correct me if I'm wrong).
    Take a look at this review among others, they're very positive.
  13. Arghnews
    Arghnews What's a Dremel?
    6 Jul 2011
    OCZ ModXStream Pro 700W
    £60 on Dabs
  14. www.syckdeals.com
    www.syckdeals.com What's a Dremel?
    28 Sep 2011
    I am sure if you look hard enough on Amazon you can find it at a far better price than 95. I have seen many items on my affiliate site marked way down from most other sites. Example my site has a listing for a Corsair CMPSU-850TX 850-Watt TX Series 80 Plus Certified Power Supply for as low as 119 canadian. Just have to do some searching.
  15. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    not heard good things about OCZ PSUs but I definitely won't paint them all with the same brush, despite that tbh I think there are better 700W PSUs around that same price
  16. xxxsonic1971
    5 Dec 2010
    its blown -up now lol!!!! lucky for me it didn't burnout anything else!!! got an xfx 850watt, 70a single rail psu now. so take it from me, don't be a skin-flint with your psu!
    cheers!!
  17. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    sums up why the list exists, no point spending £600+ on your rig then trying to save on a PSU that will eventually murder it all
  18. ryandigweed
    ryandigweed What's a Dremel?
    7 Oct 2011
    Thanks for this list of reccomended PSU's. I hope it is updated :) and if only i had stumbled upon this thread before i picked up my Coolmaster Xtremepower 500W lol
  19. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
  20. Vinnm
    Vinnm What's a Dremel?
    26 Oct 2011
    What do you guys think about High Current Pro HCP-750 750W TX12V v2.3 / EPS12V v2.92 SLI Certified CrossFire Certified 80 PLUS GOLD Certified Modular Active PFC Power Supply. I'l be buying that in a couple of days to power up my Lightning Xtreme Edition GeForce GTX 580.
