PSU Recommended PSU List - Listed On First Page
Discussion in 'Hardware' started by Moyo2k, 22 Aug 2009.
  1. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    List is being redone to update it for Q1 of 2010 - The Enermax Revolution earned it's rightful place on the last list and will be returning
  2. jon1984
    jon1984 What's a Dremel?
    30 Dec 2009
    Has anyone seen the new OcUK Modular PSUs? 650W for about £43 seems pretty decent but just wondering what everyones thoughts are on them.
  3. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Junk - probably EZCool or some other notorius brand... e-tailers will stick their name on the front of unknown products to mask the fact that the brand is unheard of
  4. Santiago1986
    Santiago1986 What's a Dremel?
    4 Mar 2010
    CM Silent Pro (M) 700W (?)
  5. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Been using a Silverstone ST50EF-Plus (500W) for 4 years and its been completely stable.
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
  7. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Back working on it again, decided to scrap the 1001+ section cos it will likely be rarely used (and because I'm too lazy :lol) Anyone got opinions on antec Truepower, Neopower etc... series?
  8. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Custom pc done a review of the antec truepower new 650w (new is important) and gave it a premium grade award for good efficiency, extremely stable, great value and having good voltages.
  9. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    Couldn't agree with you more - I got the exact same psu for my dual xeon W5580 system, with a 5870 GPU and it handles it fine. And at least it doesn't look the same as all the other PSU's.
  10. cjmUK
    cjmUK Old git.
    9 Feb 2004
    It actually looks quite cool - very stylish. But it's looks are wasted, sitting buried in the bottom compartment of my P180B...
  11. sid1712
    sid1712 What's a Dremel?
    4 Apr 2010
    Well, it's my first post here.
    Gotta say that my HX750 is one hell of a PSU. Though the X-750 is better, I couldn't get a hold on one and I settled for the cheaper HX750 (was getting it for ~ $150) which has been great.
    Running a 5970 + PII 965 C3 @ 3.8 easily. :D
  12. kovacs
    kovacs What's a Dremel?
    17 Mar 2010
    proud owner of an ocz modxtream 600w psu.Bought it after the last psu test in custom pc.It was actually the 500w that got good reviews but as i could 600w at the time thats the one i got.Read my sig,this is the first pc i have built and if you look at the parts they have all received good reviews in the mag.I'd just finished building it when they ran the feature on how to build your own pc.All the components are pretty bullet proof as ive not managed to fry anything yet.
  13. d3m0n_edge
    d3m0n_edge Lost Is Your Soul
    11 Oct 2009
    Wow. After looking at the poll, I should have chose Corsair over Enermax. :(
  14. civicteer
    civicteer What's a Dremel?
    26 Apr 2010
    Hi guys,
    I know there is a lot of good info on here but I'm utterly confused over what PSU to get! I have thinking of getting Corsair 550W VX Series PSU.
    I need a new PSU to replace my generic, noisy, no internal fan 500w which seems to cope fine under load but it does seem rather crappy. The lack of internal fan is causing come cooling problems too.
    I have AMD Phenom x4 955 BE
    Nvidia 8800GT
    2 x 2GB DDR3
    2 x DVDR
    2 x 80mm case fans
    I will want to upgrade the graphics card in a year or so and I do play games but I won't be overclocking at all!
    From what I can work out that PSU I've found will be fine, I just want a little reassurance :)
    Also at nearly £70 its quite a lot, I know you should not buy a cheap PSU but if you can suggest a cheaper one that's also good that would be great!
    Any advice would be great
    Thanks
  15. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Best thing I can see for around that price range would be the Seasonic M12II 600
  16. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    As you all know the list has been under construction for ages but sometime very soon I'll get round to finishing it as well as adding those Antecs
  17. cjmUK
    cjmUK Old git.
    9 Feb 2004
    An excellent choice...
  18. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    By the way, Corsair TX750 here, running for almost 2 years now, even survived a power surge that borked the motherboard; good stuff (although I've never loaded it more than 300W :worried:)
  19. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I was trhinking we should make a similar thread for case fans since it's so hard to tell what's a good fan from statistics alone.
  20. Hamehax
    Hamehax Destroyer of words
    5 Apr 2010
    I personally am a fan of corsairs power supplies as they have a unique build quality :D
