Portable Recommended WP7 smartphones?
Discussion in 'Hardware' started by GeorgeStorm, 17 Jun 2012.
  1. GeorgeStorm
    16 Dec 2008
    As above really.
    Just picked up a couple of smartphones, one for me and one for my brother.
    A HTC Trophy 7 and HD2.
    Currently running a gingerbread cyanogen ROM on the HD2, and stock on the Trophy.
    Anyone got any recommendations for apps? I'm not bothered about games or anything like that.
    Also anyone had any experience with the HD2? I'm looking to boot directly into android, but am not sure how to do it without plugging the phone in, and sadly the usb connection is very dodgy, so that isn't really plausible.
    Also if anyone knows a way to get a W7.5 ROM onto the phone without plugging it in, that would also be awesome :)
  2. longweight
    7 May 2011
    Tapatalk for forums is amazing, probably the app I use most.
  3. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    There's some very nice fitness apps, quite ingenious in design!
    Apart from that I bought titanium backup pro to make rom switching easier. I also always have Kindle and Moon reader for when I want to read.
    And finally definitely definitely get MX Video player, it's just the best one out there and I've tried many!
  4. JimmyTheTrumpet
    JimmyTheTrumpet What's a Dremel?
    7 Jun 2012
    BBC Radio Player
    eBay
    Amazon Mobile
    Calendar Search
    IMDb
    Photosynth
    Skydrive
    Sports Tracker
    Supertube
    Absolute Radio
    BBC Podcast Lounge
    Metro
    RAC Traffice
  5. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    JuiceDefender.
    Go Pro, but not Ultimate.
    Worth every penny.
  6. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    tubemate as well - how does it fare against supertube?
  7. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    If you're on a limited data tariff, it might be worth looking at NetCounter - handy little app for tracking data usage.
    Also, for radio it's worth looking at TuneIn Lite
  8. GeorgeStorm
    16 Dec 2008
    I just switched to one with 1gb data (coming from none)
    No idea if it will be enough, if not then I'll get back on the phone with virgin and see what they can offer (was offered my current one which is their £15 tariff for half price when I said I was switching to giffgaff). Otherwise I can go with my original plan, which was giffgaff which offer 'unlimited', so I wouldn't have to worry about small amounts of usage by apps etc, only if I started download several GBs a day would I then be in trouble :p
    Trying the Trophy now, and I must admit first impression is W75>>Android/W6.5.
    Will have to give it a little more time though, started to get used to the larger screen size of the HD2, and began to actually quite like it. (I'm coming from a £7 nokia with a tiny screen)
  9. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Scramble...totally addictive word creation game against the clock/opponent.
  10. Beasteh
    Beasteh What's a Dremel?
    18 Feb 2012
    Preach it!
    Seconding the recommends for Photosynth and Skydrive.
    Connection Tiles is a good app for changing wifi on/off from the home screen.
    Redlaser is a nifty shopping app - scan an item and see if it's cheaper online!
    Adobe Reader - sure, you've got Office on your phone, but can you read PDFs?
    Poynt is a local search app to find things near you.
  11. GMC
    GMC Minimodder
    26 Jun 2010
    Dropbox, google drive, newsrob, evernote...
    Sent from my HTC Desire HD using Xparent Red Tapatalk 2
  12. PsYcHoTiC_MaDmAn
    PsYcHoTiC_MaDmAn Unholy Cyborg Fruit Machine
    11 Jan 2011
    found it very useful to begin with, however started causing wakelocks and drained the battery, worth noting, if you have ICS then it has a built in web usage counter, with alarm functions to warn you when you approach the limit.
    personally I like opera mobile - however since the ICS update it has been battery heavy (not definite its at fault yet - experimenting with an alternate browser currently to see if there’s any improvement)
    I like N7 player for organising my music (though as far as I can tell lacks a random play function)
    in terms of monitoring what my phone is doing, better battery stats (free via XDA forum) and CPUspy allowed me to locate what caused my battery to drain (hence finding the issue with netcounter.)
    currently trying to adjust my ICS settings as I've gone from 2 days with good usage to 1-1.5 days battery life, coinciding with web browsing and opera being responsible for 40% + battery usage (hoping to get some assistance on XDA as to the cause of this)
  13. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Yeah I noticed opera drain too, it's a real shame as Opera is the very best browser you can get. Ever. It's extremely quick and intuitive to use and speed-surf across the web. My opinion of course but I'm pretty sure if you try it you'll be impressed:)
    Also, what is this better battery stats you talk of? is it an app?
  14. murraynt
    murraynt Modder
    6 Jun 2009
  15. GeorgeStorm
    16 Dec 2008
    Not really, you have to hold the cable at a rather extreme angle, and the slightest movement it may disconnect :/
  16. murraynt
    murraynt Modder
    6 Jun 2009
    How do you charge it? Maybe you should try and replace it?
  17. GeorgeStorm
    16 Dec 2008
    Came with 3 batteries and a charger.
    And replace the port or the phone?
  18. murraynt
    murraynt Modder
    6 Jun 2009
    Ohh I see.
    The port :)
    If you hold the usb in the proper position you can flash what you need?
  19. GeorgeStorm
    16 Dec 2008
    I might see if I can, not sure if it's worth it though.
    Depends how much it would cost, as I've said above, I'm far preferring W7.5, so I'll most likely either give the HD2 to my brother, or sell it on at this rate.
    I think what I really want is the HD7 (updated HD2 which comes with W7.5 it seems)
  20. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    I had gingerbread on my HD2, had to plug it in to root it etc. The dodgy connection could be the little tongue thing in the port on the phone, it its a little out of line the connection will become flaky. Try using a penknife to straighten it out.
    As for apps? 3G Watchdog for your mobile internet, you can set it to cut off your mobile net when you reach the limit so you don't start paying extra. K9-mail is a pretty decent mobile app as well. Try Google Chrome mobile as well, very good browser.
    Sent from my Galaxy Nexus using Tapatalk 2
