Recovering photos from Android phone
Discussion in 'Tech Support' started by ElThomsono, 17 Sep 2022.
  1. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    TLDR, how do I get photos off a phone with a dead screen?
    Laura's phone hadn't been backing up its photos as she'd used up all her cloud storage, about six months after this our toddler got hold of the handset and something happened to the screen, it's 100% dead, zero input or output.
    We paid to upgrade her storage hoping the phone would then back up the six month backlog of photos, but it's not done so. The handset powers up and does the little vibrate chirp as you select it on the switch so it appears to be alive in some way.
    Plugging it into a laptop doesn't seem to do anything, presumably the phone needs to authorise the connection?
    The quote we had for a new screen was more than the phone was worth, but less than the value of the photos. Is there another way?
  2. sandys
    sandys Multimodder
    26 Mar 2006
    Which brand if its a reasonable good one you can plug in a USB dock
  3. ElThomsono
    18 Mar 2005
    OnePlus Nord 5G, can you elaborate on this?
  4. sandys
    sandys Multimodder
    26 Mar 2006
    On many android phones you can plug a PC usb dock in and use a monitor with mouse and keyboard, general exceptions tend to be Chinese stuff like that but worth a shot if you have one.
    port appears to be usb2.0 so I don't hold out a lot of hope.
    ElThomsono likes this.
  5. sandys
    sandys Multimodder
    26 Mar 2006
    Other than that just plug it straight into PC and hope that it comes up in a media mode, this is quite likely and pull photos from folders, you might need to do finger print unlock first
    if you have a pin code phone lock, yu should be able to plug a keyboard into to do the pin.
  6. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Have you looked into replacing the screen yourself (if that is indeed the issue ie. not a duff board or otherwise damaged internals)? I just replaced two myself with mixed results - one has come back online but with an area of the screen non-responsive, which could be due to a dodgy re-connect or a ribbon cable I shafted. The other has come back exactly fine which is surprising, considering I pretty much separated the layers of the screen itself when removing it, but it still has the battery issue I was trying to fix.
    If it's not too difficult based on YouTube videos, might be worth a shot just to see if you can get the photos back and then recycle it.
  7. kenco_uk
    28 Nov 2003
    Perhaps grab a usb-c to hdmi cable and see if there's any output to a monitor/tv.
    If so, and if the touchscreen part of the screen isn't working, try a usb-c dock as sandys has suggested. Perhaps something like this.
  8. ElThomsono
    18 Mar 2005
    Cheers guys, I tried my USB-C dock in the house and it recognised a connection but did nothing, the one I have at work doesn't either but frankly that was hopeful, neither is a proper USB-C hub.
    I'm now looking at cost options of buying a proper Android compatible hub or trying my hand at doing the screen, or chucking a fiver at an HDMI and seeing what's what :geek:
    Thanks for all the input :thumb:
  9. wolfticket
    19 Apr 2008
    Fairly sure the Nord doesn't support display output over USB (USB-C 2.0 and no MHL).
    By design phones these days won't let you access files over USB without unlocking and manually activating file transfer (for security).
    Result is that unfortunately you'll likely need a new screen.
  10. sandys
    sandys Multimodder
    26 Mar 2006
    As @wolfticket has alluded to as it is USB 2 it is unlikely to work, there are ways to get display from USB 2.0 by Displaylink adaptors and the drivers for such are in Android but you may need to approve use first which you'd be stuffed by with a broken screen but some docks from the likes of dell have displaylink if you are looking at what you might have in the office.
