Modding Red Acrylic
Discussion in 'Modding' started by JitsuSparty, 2 Sep 2012.
  1. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    quick question - Firstly has anyone used Kustom pcs Mars Red fluorescent acrylic (http://www.kustompcs.co.uk/acatalog/info_2195.html, as I am looking to use some in a mod and want to know if it is see through enough to put a decal on the inside and see it on the outside.
    cheers in advance
  2. Archtronics
    Archtronics Well-Known Member
    27 Jun 2006
    Drop them an email and he will send you over a picture of what you want
  3. Cheapskate
    13 May 2007
    http://www.perspex.co.uk/
    The front page has different slide shows featuring fluorescent materials. Hit refresh a few times and you should get a better image of your plexi than a red square.:eyebrow:
    FL orange and red is a little cloudy compared to the other colors, but I think you should be able to do it.
    ...Then again I've never used Perspex's mix.
  4. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    cheers guys :)
  5. Booti
    Booti Member
    17 Jan 2011
    Drop Graeme a mail at Kustom, he is really helpful and will get back to you within the day normally.
  6. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    Been playing mail ping pong with Graeme and he is extremely helpful :)
