Scratch Build – Complete Red Carbon Desk Build (completed)
Discussion in 'Project Logs' started by Dirk kramer, 7 May 2016.
  1. Dirk kramer
    Dirk kramer What's a Dremel?
    13 Oct 2015
    Hi everyone,
    After building my first desk build, I decided to make a new desk but then of STAINLESS STEEL.
    After quite a few desks to have viewed with as great example the l3p desk of Peter Brands, I have created a design.
    The desk is made with the help of my father and BOS Machine Construction from the small village where I live called Urk.:)
    Because they like my build in the Netherlands, I will also post it here.
    Using some of the pictures I'll show you the build, and sorry for my bad English I hope it gets better.:D
    Some of the parts for the build.
    Hardware:
    Motherboard: Asus Maximus vii Ranger
    CPU: Intel I7 4790K 4.0Ghz
    GPU: Asus GTX 970 Strix 4GB
    RAM: 2x Corsair Dominator Platinum 2133Mhz 4Gb
    SSD: 2x Samsung Evo 840 120Gb
    HDD: 2x Seagate Barracuda 1TB (Storage)
    PSU: Corsair HX1200i (was RM850)
    Monitor: Asus PG279Q
    Cooling components:
    Pump:
    EK-DCP 4.0 PWM X-RES
    Blocks:
    EK-Supremacy EVO- Nickel
    EK-Mosfet ASUS M7G- Nickel
    EK-FC670 GTX DCII- Nickel
    Reservoir:
    2x Bitspower water tank Z-Multi 250
    Fittings etc:
    18x EK-HDC 12mm G1/4 – RED
    8x EK-AF Angled 90 G1/4 Nickel
    1x Bitspower 1x Valve Matt black
    2X EK-Ekoolant EVO Blood red 1L
    1x Silver KillCoils by Mayhems
    EK-HD PETG Tube 10/12mm
    Masterkleer Hihgflow ½ ID
    Fans:
    4x Be quiet Pure Wings 2, 120mm
    10x Be quiet pure Wings 2, 80mm
    4x Nexus 80mm Fan
    Radiator:
    EK-CoolStream PE 480 Quad
    Other stuff:
    Corsair (Link) Commander mini
    Lamptron FC-5 Fan Controller 4x 30W Channels Silver V2
    2x Goobay tv Easyscope Twin
    RGB Ledstrip with controller
    Bulgin Power Switch
    And some random cables from INLINE
    My first desk build made of mdf.
    Some photos of the build.
    The plastic plates for the bottom of the bin, with sound absorbent rubber.:)
    The bin wrapped with various types of carbon
  2. Dirk kramer
    13 Oct 2015
    Update
    Time for some coolant parts, love EKWB.
    The 4 x 120 radiator is sponsored by my brother. Thank you:)
    Ready for some bending.
    This is really a handy tool for the ends of your tube, no sharp edges.
    There is a start, now comes the more difficult part the connection between the CPU and Mosfet Block.
    For the loop in the back of my tray I have flexible hose used so that I can play with the pump easier.
    Time to fill.
    The most beautiful part of the loop. :clap:
  3. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    Nice build man :thumb: :dremel: But this isn't a project log..... I mean your build is completed in two posts with pictures... :rolleyes: :eyebrow:
  4. Dirk kramer
    13 Oct 2015
    Thank you, but that is not true there is still much more to see in this build. He's not finished yet. :rolleyes:
  5. Dirk kramer
    13 Oct 2015
    The Corsair HX1200i exchanged for RM850. :D
    The cables extended with an extension kit from Cablemod.
    A nice PCI-E Gen 3.0 extension cable of Li-Heat Industry.
    And some extension cables for my fans.
    Here some action shots.
    The power supply I have mounted under the desk, I did this to get a better flow in my rear section.
    And the corsair link commander in the system to an easy overview of all temperatures and speeds.
    The rear four fans are with the Lamptron FC5 operated.
    And for finish a nice metal plate of Black mesh :D
    And of course a RGB LED strip can not be missed. First I made a diagonal of aluminum and the LED strip is attached with 3M tape, and mounted on the front of the desk.So it does not shine in your eyes.
  6. Cwiver
    Cwiver What's a Dremel?
    12 Jan 2015
    Where did you get your cable combs from?
  7. Dirk kramer
    13 Oct 2015
    The cable combs are from a company called Cablemod https://cablemod.com/
  8. Dirk kramer
    13 Oct 2015
    Final Pics
    Here the final shoot , have fun:clap:
    See you next time :D
  9. l3p
    l3p www.^.nl
    1 Nov 2010
    Nice going Dirk :thumb:
  10. Dirk kramer
    13 Oct 2015
    Thanks Peter :lol:
  11. Cheapskate
    13 May 2007
    Nicely done. No toe-killing parts either.:D
  12. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Really great job. :clap:
  13. Dirk kramer
    13 Oct 2015
    Thanks :thumb:
  14. Praelia7or
    Praelia7or What's a Dremel?
    16 Apr 2016
    Really nicely finished desk build! Tidy tubing runs always add a bit of class.
  15. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Thats a freaking awesome build :D
  16. Dirk kramer
    13 Oct 2015
    Thanks :clap:
