Modding Red Film?
Discussion in 'Modding' started by error.ini, 11 Oct 2003.
  1. error.ini
    error.ini What's a Dremel?
    25 Aug 2003
    I got a CCFL from SVC, and it's so pink, it's almost white! I'm looking for red film to put over it? I went to Office depot to see if they have red overhead transparencies, but they don't. I right now, I'm using clear plastic, and a red perm marker, but it doesn't look so good..
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    i assume you have a printer? just get a sheet of printable OHP transparency and print a page of red :D
  3. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    If you know any local theatres, ask for some Red Gel material, they are bound to have extra. you might have to pay though.
  4. chairman666
    chairman666 What's a Dremel?
    27 Sep 2003
    use red cellephane(not sure if thats spelled right)....u can get it at craft stores
  5. DRxAndy
    DRxAndy What's a Dremel?
    6 Mar 2003
    i've heard on a tip from another modder (rosonoski) that using brakelight tape found at an auto parts store works great
  6. error.ini
    25 Aug 2003
    PERFECT! I just happening to be going to the car store tonight to get tint! Thanks!
    Thanks for the other suggestions also.
  7. Dogg
    Dogg What's a Dremel?
    14 Sep 2003
    be warned.. that stuff can be needlessly expensive.. but yeah, it'll work.. (you can do a decent job for cheaper tho for some of the previous ideas) (the red gel would be perfect.. thats what its made for.. most theatres (stage not cinema) do have em.. a lot of times if ya can talk to the actual lighting guy, hes got scraps lying around)
  8. purple
    purple Minimodder
    10 Mar 2002
    go to sweet shop.....
    buy quality street....
    eat the red ones carefully saving the wrappers..
    voila!! red celephane in conveniant squares!!
  9. luvbug
    luvbug What's a Dremel?
    22 Sep 2003
    Red Saran Wrap. cling wrap.. like you cover foods with.....
  10. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    I converted a white CCFL to blue with a piece of blue plastic I cut out of a plastic bag...
  11. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Gels work well if you can find them. There are even special tube shapped ones for florecent lamps.
