Linux Red Hat on a big flash drive...
Discussion in 'Software' started by dawolfman666, 17 Oct 2007.
  1. dawolfman666
    dawolfman666 What's a Dremel?
    10 Mar 2003
    ok I'll try it out.
    I decided to drop the flash stick idea...due to the low transfer speeds and the read/write concerns and went for a mini external drive.
    maybe I should start a new thread instead.
  2. Krikkit
    21 Jan 2003
    You could easily get it to run on a properly fast flash drive - something like a Corsair Voyager GT is actually faster than most small drives.
  3. dawolfman666
    10 Mar 2003
    anyway this is what I've got. After disabling the IR port and the parallel port in the bios it still hangs either during the boot up, at different points each time. After reading a few other forum posts it looks like I should have installed the grub loader to the MBR of my external drive instead of my internal....which is what I've done...but windows boots perfectly well from it...so I don't see what's the fuss about.
    on one boot up attempt it brought up:
    scsi 0:0:0:0 rejecting I/O to dead device
    Any ideas?
    I gave the feedora7 Live CD, this worked a little better I got in to the OS but then it hung after a while...it didn't seem to like my external mouse/keyboard (USB)
    I'm going to try and put the following command in the boot loader, as I've seen this on a few other pages.
    mkinitrd --preload ehci-hcd --preload usb-storage --preload scsi_mod --preload sd_mod --force-lvm-probe
  4. dawolfman666
    10 Mar 2003
    ok that didn't work...no when I boot up it loads all the services then looks like its loading the drive (I see my GFX card name but it disappears to quickly) then the screen goes blank......sigh....anyone?
