Cooling Red LED PWM Fan
Discussion in 'Hardware' started by Moyo2k, 26 Sep 2009.
  1. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Need a RED LED PWN fan to replace fan on a HSF, anyone seen any, all I've seen are blue
  2. Krikkit
    21 Jan 2003
    Size?
  3. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Ahh sorry 120mm
  4. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    It seems the only ones are Blue LED, and even those are rare, what does the 4th pin give me over 3 pins anyway?
  5. Krikkit
    21 Jan 2003
    The 4-pin ones have a slightly different method of PWM to normal. The 4th pin gets a lower voltage fed to it to use as the lower voltage in the PWM cycle, to avoid having a 12V-0V step.
    Apparently it avoids any vibration from the fan spinning up, slowing and idling with such a big voltage difference.
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Interesting, has this ever been tested?
  7. Krikkit
    21 Jan 2003
    What, the vibration? I doubt it, but I can see why it'd be an issue on fans which aren't properly secured. I'd just stick with 3 pin tbh.
