Case Mod - In Progress Red Lian - Li V1020
Discussion in 'Project Logs' started by skullen, 6 May 2013.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    Hi all time to start a new build,have been huffing and puffing with a few ideas but wont bore you with a load of pics i have.
    My aim for this build is to try and make it a tidy build,nothing as posh as the builds that are going on here.
    The case
    Wheels were painted,not every ones cup of tea but i like them.
    Got some 3mm Acrylic for the bays and midplate.
    Heat bent and fitted for look see
    Ive stuck on a PSU extention bracket so it gives me more room under the plate for wires and thats where the HD is going.
    Have ordered some chrome tubing and push fittings to have a play with.
    Some of these from E22,should look ok with the chrome tube.
    Raystorm CPU Block and a Tank res will be ordered soon,when funds allow.
    Had a play with sketchup to see how it might look,not brill but you sought of get the idea.
    Might also get a window cut.
    Thats where i am at the mo still a bit of a way to go,as i said just want to try and build a tidyish case.
    Thanks for looking :thumb:
  2. Cheapskate
    13 May 2007
    Long time no see. -Ok, that phrase never made any sense to me, but HEY!
  3. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    dunno why but big LL cases on casters always made me throw all my "custom cases" in the waste bin :D
  4. skullen
    skullen Minimodder
    31 Oct 2007
    Hey Cheaps.
    My wheels aint every bodys cuppa,i like em and there staying on :D
  5. skullen
    skullen Minimodder
    31 Oct 2007
    Got my chrome tube so i thought i would have a play.
    Still got loads to do and get.
    Thats where i am at the mo.
  6. skullen
    skullen Minimodder
    31 Oct 2007
    Time for a refresh,got some new bits to play with.
    Treated my self to a new AC Aqualis tube Res and some nice Blood Red fittings.
    XSPC Barbs clear tubing and Acrylic tube used as well.
    Pics
    DD Rad Res brackets used as the tubes are the same size
    Added some fittings
    Fittings sorted
    Juice added time for leak testing
    Where i am at the mo,
  7. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    is the case red , purple, or hot pink?
