also comes my mod! the case will be an old hp compaq d220mt a microtawer for the accuracy ...... already understand from the name which will be more or less one of the colors of this mod ..... I hope you will follow me in so many ....... here's a picture for you to make the idea I will start as soon as possible with the passing of the photos and start work
I always read these threads & I'm normally gobsmacked...........I'm a little bit lost on this one but I'll hold off till something actually happens.
Generally the rule is that you don't post a log until you have some actual modding to show. Hopefully we wont have to wait too long.
today with the opening of the shops I took the opportunity to go and buy the Or then I have done substantial work .... I first covered with paper tape the side plate and traced the outlines of the "window" ..... unfortunately I made a mistake while cutting 5mm but do not worry I immediately rebuilt with filler metal I waited for it to dry final result
well central monitoring station in our intensive care unit (12 beds) is based on HP PC in such case (2,4GHz northwood AFAIR) i'll watch
and here are the parcels sent by the sponsors! What's inside? I forgot to take a picture of the pack corsair : (
here's what he sent prokoo. Thank you very much for having believed in my modding! Why I chose the following material? katana 4 because aesthetically and then convince me why I needed a heat sink that came within 18 cm of the case! the mouse: I needed something ergonomic fit my hands with adjustable dpi fast and aesthetically suited to modding!
here's what I bought protective gloves mini screwdriver with many tips permanent marker sponge anti-vibration screws m5 aluminum panel screwdriver slit I first took the aluminum panel, and I have drawn on the panels almost triangular in shape! subsequently cut
and here are the products that you sent me cooler master......... watch the video on my channel: Rock:: Rock:: Rock:: Rock:: Rock:: Rock: https://www.youtube.com/watch?v=xBg1L8x3QFM
if any of you are writing to xtreme hardwere .... please help me out by voting RACING SIMULATOR there'll be 'grateful! link to which voting http://www.xtremehardware.com/forum/f70/contest_lamptron_cw611_n_3_modding_project_votazione-39029/
