Linux Redhat 9
Discussion in 'Software' started by omicron, 2 Sep 2004.
  1. omicron
    omicron Baud.
    8 May 2004
    Hey guys..Got a bit bored and found my redhat 9 CDs lying around so I decided to install again, and everything works! (touch wood!) I'm just trying to figure out how to change the resolution - I had this problem last time when I had a GF2, :hehe: which died..so I'm using onboard GFX..:blah:..basically, when i change resolution it tells me to restart the X server..so I do, and when i log back on it's still at 800x600.. I've googled a bit, and searched the forums, but havent *really* found anything.
    Let me know if you can help out / if theres anything I can do to help you understand the situation better (I'm a newbie at this Linux malarky) ;)
    Cheers, Mid
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    what mobo?
    I had to change some stuff in the bios to get X to go to 1600x1200 when I used onboard..
  3. omicron
    omicron Baud.
    8 May 2004
    Still using a cranky ol' ECS K7VMM mate
  4. ajack
    ajack rox
    17 Apr 2003
    Edit your XF86Config file. There are many guides around :)
  5. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    Run as root > redhat-config-xfree86
    -scoob8000
  6. trigger
    trigger Procrastinator
    22 Mar 2004
    You may have already done this, but CTRL ALT +/- should change the resolution from the options available in your XF86Config file...
  7. scoob8000
    17 Feb 2002
    Sweet!! Just learned something new!
    -scoob8000
