Windows Redirecting a web page
Discussion in 'Tech Support' started by SeT, 25 Jun 2010.
  1. SeT
    SeT What's a Dremel?
    7 Oct 2003
    I've been searching the majority of the morning and haven't been able to come up with a way to do this. Does anyone know if it is possible to redirect a sub URL of a web page. What I mean is, say someone on my computer goes to espn.com. Fine. I don't mind that. But what if they go to. espn.com/blahblah. I want to redirect that to another page. Either locally stored or online doesn't matter, it only needs to happen on one computer. Is this possible?
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    SeT likes this.
  3. SeT
    7 Oct 2003
    looks more complicated than I was thinking but that should do the trick. Thanks!
  4. sandys
    sandys Multimodder
    26 Mar 2006
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    This is what you're after:
    <meta HTTP-EQUIV="REFRESH" content="0; url=http://www.site.com">
    Alternatively, you can set it in your host's cpanel.
    thehippoz likes this.
  6. notatoad
    25 Jun 2004
    i think you guys might have misunderstood the question. those will redirect the page for everybody and require you to have admin access to the site in question. i think the OP is just trying to block a site on his computer.
  7. tominated
    tominated What's a Dremel?
    28 May 2008
    wouldn't you do something like what SeT wants in the hosts file?
  8. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Ah, yeah i don't think he actually owns the sites he want to redirect.
    I *think* you can do it in the hosts files, i do use windows any more and i can't remember what the hosts files config is but it's something like:
    site.com 127.0.0.1
  9. SeT
    7 Oct 2003
    The hosts file will not work. It would work if I wanted to completely block the entire domain site.com but I want to be able to access site.com, just not site.com/url. Also, I do not own the site in question so the html redirect will not work.
    Having some trouble with Privoxy, it worked to redirect once but hasn't worked since.
  10. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Can you add the / in the host file?
    site.com/suburl 127.0.0.1
  11. SeT
    7 Oct 2003
    no. the hosts file doesn't recognize the /. It does entire domain or nothing at all.
  12. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    there's a thing called content advisor in IE.. under the content tab in options
    enable that and add the url
    you'll have to approve all the sites and enter a password once.. but after that you should have that page blocked.. make sure you pick view website always instead of view webpage on the password part
  13. notatoad
    25 Jun 2004
    mac and linux both have hosts files too, they are located at /etc/hosts and the syntax is the same as the windows hosts file.
  14. SeT
    7 Oct 2003
    I considered content adviser in IE but I want to redirect, not block. the password kinda ruins it too.
    Basically, it's a prank(sorta, I'm not going into all the details here). I've got a site created that I want to redirect someone to if they go to certain specific URL. I don't want to redirect all of espn.com but I do want to redirect espn.com/blah or myspace.com/blah or facebook.com/blah... Content Adviser and Hosts file are both all or nothing. Privoxy looks like the best option so far but the rule still only works once after it has been created.
    Edit: I take that back, Content Adviser actually will block the specific url that I want and not the whole of the site but the password still ruins it and I want a redirect, not block...
