Electronics Reduce headphone volume in hardware
Discussion in 'Modding' started by jezmck, 16 Jan 2006.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi everyone.
    When I use my headphones I have to have the volume(s) set right down, and hence lose precision over the volume control.
    Can I add some resistance to the signal to reduce their volume?
    Any ideas / suggestions are welcome.
  2. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    A potentiometer should work, but I don't know what value you should use. I would try a 10K pot (outer two pins to computer signal, middle and one outer pin to headphones.)
  3. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Depending on whether you want to adjust the volume or not.
    If you don't, then a small value resistor on the ground wire would work, if you do, then a pot on the ground wire would be your best bet. You'd need a lowish value though, I think.
    __
    / o \
    |___|
    o o o
    1 2 3
    Put the ground in series with pins 2 and 3 irrc :)
  4. jezmck
    jezmck Minimodder
    25 Sep 2003
    it would be best if I can make something with male and female 3.5mm jacks so I can just add it where it plugs in.
  5. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    %k to 10K is about right, however, if you want individual volume controls for L / R then put one Pot on each signal line, with the middle pin from the mobo and one outer pin to the chanel, same on the other channel.
    if you want one 'master' volume, just put the 10K pot on the ground line, with the middle pin fromt he mobo and an outer pin to the headphone ground
