Electronics reducing volts to fan
Discussion in 'Modding' started by SpikeyJake, 22 Jul 2002.
  1. SpikeyJake
    SpikeyJake What's a Dremel?
    23 Sep 2001
    Whats the best way of reducing the voltage to fan without using a rheostat . I know about the 7volt thing , but iam just wondering fi there is any better ways .
    Thx for nay help
  2. Telkman
    Telkman What's a Dremel?
    22 Apr 2002
    Reostats use variable resistors in some form, you can of course just used fixed value resistors to reduce the voltage to a certain level, or swap the wires round to give a constant 5volts, not 12
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Your choices are,
    (a) Resistive (either fixed or variable eg rheostat)
    (b) Diode junctions - waste 0.75v per diode
    (c) Linear regulation - a partly-on transistor wastes some volts
    (d) Pulse-Width-Modulation - switch the supply on & off so fast the fan can't catch its breath
    (e) Switched-mode power supply - DC-DC conversion, a sledge-hammer to crack a nut perhaps
    <pimp>
    Some circuits at Fan Noise Solutions and in several Bit-Tech articles.
    </pimp> :D
  4. SpikeyJake
    23 Sep 2001
    I understand a and b choices , but the other 3 iam not sure about . Thought after reading ur website iam going for choice b .
    Thx for the help
    sj
