Cooling Refrigerated water cooling.
Discussion in 'Hardware' started by bajastx, 21 Feb 2002.
  1. bajastx
    bajastx What's a Dremel?
    22 Jan 2002
    Should I worry about condensation on the waterblock or anywhere else if I use a refrigerator in my cooling system.
    I've got an extra 1.2 cubic feet (In the UK that means small) refrigerator that I was thinking about putting some type of heat exchanger in for my water cooled system.
  2. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Yes. The fridge will drop the temps down to below the rooms ambient, causing condensation. Although I'm not sure how effective a mini fridge would be, as they're not really designed to cool a heat source. But, hey try it. If it works, post your results. ;)
  3. Haddy
    Haddy World Domination
    22 Jan 2002
    yea this time watch out for condensation on ur lines and ur block cause ur basicly makin a giant chiller cools the water unlike a tec which just cools the block
  4. bajastx
    22 Jan 2002
    ... and is it a good idea to put a fan on a radiator if in a frig? I'm not sure if it would make much difference.
  5. XkwiSit
    XkwiSit What's a Dremel?
    5 Feb 2002
    I'd say it would be not needed but have an even greater effec having a fan, otherwise might not be worth putting it into a fridge..
    small space, stagnat air, (no movement whatsoever - other than convection)
  6. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    the way i solved the problem of condensation was to put the computer inside the actual fridge itself. it should be done by the end of march if i order all the stuff for it. ive got some pics of but i cant put them up till tuesday.
  7. bajastx
    22 Jan 2002
    Right... that's what I was thinking. It'd probably just blow a little more heat off the fan, but where would it go??? Nowhere! But I think I'll give it a try just to make sure.
    You know "theory" has been proven wrong before. ;)
  8. brianpodskalny
    3 Nov 2001
  9. Tiger
    Tiger What's a Dremel?
    25 Feb 2002
    For sure you have to worry about it. I have mine running at -25C and have 12mm closed foam around it.
