Basically I'm not particualry sure what I'm doing in life in Reg Expr(So please excuse the mess), just a quick bit of code as a example Code: private String NameCountryData; private String [] Country; private String [] surname; private String [] name; NameCountryData = "England (2006)/Blogg, Fred/Davey, Jen/Doe, Jane" title = NameCountryData.split("\\(\\d\\d\\d\\d\\)/"); //Splitting the data in half from England(whilst removing (2006) so have two array positions one with "England" in and the other containing the rest) surname = title[1].split(); //these are the two lines I'm struggling with, not sure what Reg Expr I need to split this on the ", " after Blogg and for the reg expr only to match ", " ONCE so I end up with only two array postions similar to above. name = surname[1].split();// Same as above I hope I've explained what I'm trying to do above reasonably clearly but the end result I want to end up with I'm trying to get to look like this: title[0] = England title[1] = Blogg, Fred/Davey, Jen/Doe, Jane surname[0] = Blogg surname[1] = Fred/Davey, Jen/Doe, Jane name[0] = Fred name[1] = Davey, Jen/Doe, Jane I assume its possible but I've spent the past two hours banging my head over this, I know its quite simple but can't work it out! Cheers if you can help Marc PS This is sample code, so most probably won't/shouldn't compile
