Development Regular Expressions
Discussion in 'Software' started by theevilelephant, 19 Oct 2008.
  1. theevilelephant
    theevilelephant Minimodder
    5 Jan 2006
    I saw there was another thread similar to this, but I didn't want to hijack it so here goes:
    In a program I am working on I need to split a string (which will be a line from a book) into words. I am programming in java, and String has a split method that takes a reg. exp. as an input which it then uses to split a string into an array of strings. My question is what would the regular expression look like?
    At the moment I have ", | " and that seems to work spaces or comma space things like "Hello, my name is tom", but something like "Hello. Are you there" would end up with "Hello." as a word in the array, when it should be "Hello". How do I make it so that the regex finds ". " or ", " or " " or ": " or "; ". I tried myself earlier but I just couldnt get it to work.
    I hope I explained it ok.... heres an example.
    "Hello, my: name; is. Bob" with the current expression yields an array filled with
    "Hello"
    "my:"
    "name;"
    "is."
    "Bob"
    what I am looking for would be:
    "Hello"
    "my"
    "name"
    "is"
    "Bob"
  2. RTT
    RTT #parp
    12 Mar 2001
    /[\w-\']+/
  3. woodshop
    woodshop UnSeenly
    14 Oct 2003
    except hes in java which i don't think has shortcuts.. or //
    so probably more like "[.,:;!$?]+"
  4. koola
    koola Minimodder
    11 Jul 2004
    Input
    Code:
    Solution
    Code:
    List<String> matchList = new ArrayList<String>();
    try {
    	Pattern regex = Pattern.compile("[\\w]+");
    	Matcher regexMatcher = regex.matcher(subjectString);
    	while (regexMatcher.find()) {
    		matchList.add(regexMatcher.group());
    } catch (PatternSyntaxException ex) {
    	// Syntax error in the regular expression
    Just iterate through the match list.
  5. theevilelephant
    5 Jan 2006
    Thank you so much!! It works, but could you explain the expression? I assume \\w is any whitespace character?
  6. koola
    koola Minimodder
    11 Jul 2004
    \w is a short-hand character class to match a Word Character (i.e. letters, digits etc). To match whitespace, use a space litteraly or the character class \s
    Hope that explains it.
  7. theevilelephant
    5 Jan 2006
    Thanks! Much appreciated :)
  8. RTT
    RTT #parp
    12 Mar 2001
    You might want to add in apostrophes and dashes (etc) otherwise stuff like "hello, my name isn't bob, it's dave!"
    will come out as
    0. hello
    1. my
    2. name
    3. isn
    4. t
    5. bob
    6. it
    7. s
    8. dave
  9. koola
    koola Minimodder
    11 Jul 2004
    Agreed :duh:
  10. theevilelephant
    5 Jan 2006
    yes! i've only just noticed that lol!
    Would it be
    "[\\w'-]+"
  11. RTT
    RTT #parp
    12 Mar 2001
    Yes as per my 1st post :)
