Windows reinstall os
Discussion in 'Software' started by CatKing, 7 Jun 2003.
Thread Status:
Not open for further replies.
  1. CatKing
    CatKing What's a Dremel?
    10 Nov 2002
    hi all,
    for some reasons i had reinstalled winxp home. i followed some guideline on the net and now i can go to window update without reactivation. however window is always reminding to activate through pop up message. how can i get rid of this message or it will go away after 30 days by itself. actually my winxp copy is bought however i had reactivated many times and had upgrade some hardwares and microsoft had refused my activation 3 weeks ago and i did not want to explain with them via phone.
    please give me some advice if i should have to activate or just ignor the message since i can perform window update.
    i just worry i cannot run the os after 30 days limit.
    please give your expert assistance.
    thanks
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Install Windows 2000 maybe ? It'd be an upgrade at teh least in stability and security.
    Also go into the admin tools, and services, and disable alerter and messenger (make sure to also stop teh services). I don't know if Home edition has that though . . .
  3. CatKing
    10 Nov 2002
    thanks.
    any more advice please
  4. CatKing
    10 Nov 2002
    any input please.
    can os still work after the time limit even i dont activate it?
  5. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Essentially whether you own it or not, you're still asking to get around the product activation.
    If you cannot activate it, you need to discuss this with MS.
Thread Status:
