Other Remote access
Discussion in 'Software' started by Ant1981, 17 Dec 2011.
  1. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    What's the best way, to control things on my desktop with my laptop over my LAN, might be a strange request, but it has some uses.
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Google vnc, or if you use something like logmein. You can access it from anywhere
  3. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Or RDP if no one's logged in at the time... (built into windows as well if you don't want to install anything)
    Or if you can see the screen from where you are and have Wi-Fi, you can look at something like Mobile Mouse for smart phones (gives you keyboard and mouse on the phone)
  4. benjjamin
    benjjamin needs MORE POWER!
    13 Sep 2010
    teamviewer
  5. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    ive been using tight VNC for a while now. havnt had any issues with it so far.
  6. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    depends on what your situation is, give a better explanation of what you are trying to achieve
    RDP
    VNC
    KVM
    loads of acronyms we could throw at you :)
    oh and not a strange request at all, would consider it almost vital for any home network to access any pc form another
  7. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Also what operating systems are you using?
  8. Pookeyhead
    30 Jan 2004
    http://www.uvnc.com/
    I've found this brilliant. I use it to access my server, which is run headless. Stable, fast, light, and free.
  9. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    1. Logmein if you regularly need access over the internet, will also work on a LAN, and allows you to share the screen (and its free).
    2. RDP if you're on your own LAN - although it'll lock the screen locally while you're on.
    3. VNC if you only use it on your own LAN and need to share the screen.
  10. Unicorn
    25 Jul 2006
    Zoon has mentioned the three that I use.
    Why would it be a strange request? I use remote desktop apps every day without fail. Most of my servers are remote desktop managed.
  11. Mojo
    Mojo Multimodder
    18 Nov 2011
    i used to use radmin but its flagged by a lot of virus scanners for some reason..
    or teamviewer do a usb edition!
  12. TrickOn
    TrickOn What's a Dremel?
    28 May 2006
    If you can see the desktop from the laptop it might be worth looking into synergy.
    It lets you control the pc with your keyboard/mouse of your laptop, just like moving to a second display.
    I haven't used it for a long while, but it was never hard to get going.
  13. TheKrumpet
    TheKrumpet Once more, into the breach!
    18 Oct 2011
    Remote Desktop is far more than sufficient for the majority of uses and it's actually fairly simple to set up. Gets my vote.
  14. TheLegendJoe
    TheLegendJoe Syntax error
    28 Oct 2010
    Run -> MSTSC Couldn't be easier!
  15. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    TightVNC, realVNC, ultraVNC any will do the job.
    Not a strange request, a good percentage of the forum readership will be using one of the above.
  16. buchanan0204
    buchanan0204 What's a Dremel?
    15 Dec 2011
    Over LAN: Remote Desktop built into Windows. Simple and very good.
    Over tinterweb: Teamviewer.
  17. Ratchet219
    Ratchet219 What's a Dremel?
    9 Aug 2011
    Logmein
  18. kitt
    kitt Michael Knight
    8 Aug 2004
    Another vote for Teamviewer+1
  19. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    remote desktop, works fine for me
