Electronics Remote control amplifier
Discussion in 'Modding' started by bard, 26 Aug 2004.
  1. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    For some reason, the remote control to my TV doesn't work well from large angles, so when watching TV from my bar, I have to aim for half a minute before even being able to change the volume. Would it be possible to build an amplifier for the remote control, which can be placed somewhere in the room to pick up the IR light, and flash a second IR led, which is aimed toward the TV. This would hopefully work for all my remotes (DVD and such). Could it be battery operated, or would the IR receiver drain the batteries quickly?
    Could I use a phototransistor from a ball mouse for this purpose?
    If anyone could design a circuit, that would be great :)
  2. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I would see if I could find which wavelength the remote uses, and find phototransistor or an IR reciever that is suitiable.
    At radio shack I have seen combo kits with an IRED and a reciever, I would think that you could just wire them in series and use a 9v battery and resistor to power the circuit. I may be wrong, you may need a logic gate to clean up the signal before re-sending it. But it would be possible to to.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Erm...could it be what you're drinking? :eyebrow:
  4. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Behave, cpemma, or I'll get my big stick.
    I've known even cpemma to be drunk or maby maybe just make a mistake... :rolleyes:
  5. Zwox
    Zwox What's a Dremel?
    8 Jul 2004
  6. bard
    8 Mar 2003
    Great, thanks! I'll look into that
