Other Remote PC with hamachi
Discussion in 'Software' started by ComputerKing, 22 Dec 2008.
  1. ComputerKing
    8 Sep 2006
    hi guys.
    I really need help. I tried everything but nothing worked with me.
    The thing is that I want to remote my PC from outside my home ( not from my home network )
    Remote thing works perfect in my home with my network ( with windows remote thing ) and it's dam good. I heard that when I use hamachi it works like my home network, I tried that and it didn't work.
    so what I do now? I really want to remote my PC throw the laptop. DEAD need :(
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Hamachi will enable you to do anything with your computer you can do over the local network, but via a secure VPN link over the internet. How you have it configured is another matter.
    If your just wanting remote desktop you would be better using LogMeIn rather than Hamachi.
    https://secure.logmein.com/welcome/get_logmein_free/signup.asp
  3. ComputerKing
    8 Sep 2006
    LogMeIn is online. I mean works from a website.
    I like windows Remote Desktop. and I want to use it, is that possible?
  4. dinjo_jo
    dinjo_jo What's a Dremel?
    11 Dec 2008
    Try TeamViewer.
  5. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Sounds like you have to set up a VPN at home to connect to first, if you don't like the logmein option. Some routers can do this, then you'd use the windows vpn client, and remote desktop connection.
    There may be other options out there.
  6. ComputerKing
    8 Sep 2006
    yeah that kinda what I want to do.
    It's like I be in my home network from any place in the world. SO i need to setup VPN connection, SO I tried Hamachi and It made one but i don't think it is working.
    So what do you think I should do ? I don't have a clue how to do it so please help me :(
  7. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    On hamachi are the computers that are in the "network" you created all displayed with a green light next to them?
    If they are yellow you won't be able to connect, they need to be lit up green to allow a virtual connection.
    I've used hamachi for this loads of times, its very good when you get it all working :)
    If the lights aren't green you will need to forward ports to the machine hosting the hamachi software on both sides. The easier way to do this is to use UPnP on your router(s) if they have the option.
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    Hamachi will do what you want, I share a network drive with my mum with it and can use Dameware to remote her PC as if we were on the same network.
    Assuming the computer you are connecting to has a green dot/star next to it you should be ok.
    If you are trying to use hostnames to connect to your computer you may need to use the HOSTS file and set them with the Hamachi IP.
  9. ComputerKing
    8 Sep 2006
    It's green and looks okay.
    but when I tried it outside. I get this error window and remote desktop stop with that error.
    but in my home with same user and pc name i don't get that error window so i don't know what is wrong.
    also port forward is done ;)
  10. Atomic
    Atomic Gerwaff
    6 May 2002
    Try using the IP listed next to SAIF-PC in the Hamachi window instead of a hostname, should start with a 5.
  11. ComputerKing
    8 Sep 2006
    tried that get same error :sigh:
    this same error if i write the IP from my netwrok or outside
    or the HOST NAME from outside my network
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    Double click on SAIF-PC in the Hamachi Window, do you get replies to the PING requests?
  13. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    In preferences there is a security tab, which has a couple of options to block users and windows services, try unblocking these to test if it works.
    Also ensure that hamachi is in your allowed list in your windows firewall if you have it enabled.
  14. ComputerKing
    8 Sep 2006
    Time Out Error for hours .. :(
    Nothing blocked and my laptop IP is on allow list with a finger print.
  15. Atomic
    Atomic Gerwaff
    6 May 2002
    Well there's the reason it won't connect. Not sure what to trouble shoot now...
    ComputerKing likes this.
  16. Delphium
    18 Mar 2007
    Sounds like a firewall issue then.
    If you go into your windows firewall you can disable it for the hamachi network connection, try doing this and test again.
    in xp goto... start > control panel > windows firewall > advanced > then unselect Hamachi
    in vista goto... start > control panel > windows security center > click windows firewall from the list on the left > change settings > advanced unselect Hamachi
    It is recommended that you leave the firewall enabled for all other devices and usually hamachi its self, but this should help find where your problem lies.
    EDIT: another thing to try which has worked for others whom had issues seeing other machines is to set the hamachi network device as the first in the network list so it has priority.
    you can do this by....
    xp... start > control panel > network connections > advanced @ the top> advanced settings > then ensure hamachi is at the top of the list in the connections box.
    vista... start > control panel > network and sharing center > manage network connections (on the left) > advanced @ the top> advanced settings > then ensure hamachi is at the top of the list in the connections box.
  17. ComputerKing
    8 Sep 2006
    Delphium buddy I don't know what to say, IT"S WORKINNNNNNNNN!!!!!!!!!!!!!!
    thanks a lot really. It's working like charm now ;) IT was because my idiot ESET Smart Security anti virus , I disabled the firewall and boom it works ;)
    man you rock ;) thanks thanks :D king of VPN
  18. Delphium
    18 Mar 2007
    Hehe, your welcome CK, glad its working :)
