Modding Remote Receivers
Discussion in 'Modding' started by davecrowley, 15 Aug 2003.
  1. davecrowley
    davecrowley What's a Dremel?
    15 Aug 2003
    Hi all,
    I've been looking at setting up a remote to use with my PC, and I wondered if anyone here has ever used the IrDa header on their mobo for this.
    Is there such hardware available, or will I have to use a Serial / USB receiver for my remote?
    Never tried anything like this b4, so any help would be much appreciated. Ta.
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    hello and welcome to the boards! :thumb:
    As far as the hardware for the IrDa it is wery easy to make.. but software is worse... i don't know any software for use with IrDa... only COM... I recently made on myself...
  3. Darv
    Darv Bling!!
    12 Aug 2002
    You should ask Meblin. He has guides on his website for making infared recievers. Although they use serial ports, not the mobo headers.
    Meblin's site
  4. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    ohhh my ears are burning :D
    The IrDA is not very good for controling your putter because of the type of signal it receives/transmits and there is very little in the way of software to control anything with it.
    I would recommend using the serial port version as it's very easy to make and there is lots of software available to do all sorts.
    Have a look at my site for more info.
    Meblin
  5. davecrowley
    15 Aug 2003
    Hey, thanx for all the help guys.
    :thumb:
    BTW : Nice site Meblin - I'm going to attempt one of those serial units.
    Cheers !
