Linux Remove getsecuritysuite popup
Discussion in 'Tech Support' started by onemaddude, 11 Jan 2022.
  1. onemaddude
    onemaddude Minimodder
    8 May 2009
    Today I was using Chrome and I discover that I have picked up the getsecuritysuite popup appearing - I know it's a fake plugin etc but the only removal infomation I can find is for windows and rather useless for Linux Mint. Can anyone point me in the right direction
    Thanks
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    All the guides I saw are about resetting your browser, which should apply regardless of the OS. You could also try deleting the Chrome settings folder, I don't know where it is but it'll be somewhere such as ~/.chrome or ~/.config/chrome or ~/.config/google/chrome, etc. If it's just a notifications popup, you can also go into settings, search for Notifications and remove the domains the popups are coming from. Typically you don't need an antivirus on Linux but you could always install clamd and run a scan.
  3. Gareth Halfacree
    4 Dec 2007
    Probably best resetting Chrome to defaults. Try chrome://settings/resetProfileSettings in the address bar, and if that doesn't work delete the profile altogether.
    EDIT: Ninja'd!
  4. onemaddude
    8 May 2009
    Thanks I will take a look after work and get back to you
  5. onemaddude
    8 May 2009
    I done both of those and am leaning towards it being the site as it only happens on that site, so easiest option is don't use it anymore:grin:
  6. onemaddude
    8 May 2009
    A little update for everyone
    Today I tried the site on a fresh install and Chrome does exactly the same, I also tried Firefox and it goes to alphaspeedbooter,com so I'm now convinced it's the site and not me
  7. yuusou
    yuusou Multimodder
    5 Nov 2006
    May wanna add to your browser an ad blocker such as ublock origin.
  8. onemaddude
    8 May 2009
    Thanks, I'll give it a go
  9. onemaddude
    8 May 2009
    Ok, I tried adblock and it blocked every ad except the "getsecuritysuite" one maybe I'll try a popup blocker too but that will have to wait
  10. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Does chrome have extensions installed which may be causing this? (When you login with chrome does it auto install extensions? Not a chrome user)
    What webpage is this happening on or all pages?
    Does this happen on any other machine on your network?
    Does it happen on a diff internet connection?
  11. onemaddude
    8 May 2009
    After trying another machine (new build too) it appears to just be a redirect advert as its only the one page. I got round it by using a different site to do the same job - it was just a file size thing the problem site has smaller files and my connection is more than a little slow (2mb) being on the edge of the exchange
  12. yuusou
    yuusou Multimodder
    5 Nov 2006
    uBlock has an "object picker" that lets you pick objects to block that it may not have blocked initially.
  13. onemaddude
    8 May 2009
    Thanks I'll give it a look
  14. onemaddude
    8 May 2009
    Hopefully my final update on this. Tried it again without an ad blocker as site doesn't like them and the problem pop up has gone so it looks like the site sorted it. still get a few "fun" pop up that I have an assortment of viruses all with windows paths/registry info :hehe:
