Cooling Remove HSF Backplate
Discussion in 'Hardware' started by Deadpunkdave, 19 Jul 2011.
  1. Deadpunkdave
    Deadpunkdave ...why you need a 20-sided die
    9 May 2009
    Hi all,
    I finally got round to returning my Rev 2 P67 board, miraculously I have all the bits but I can't get the backplate from my Gelid Tranquillo off the damned thing. Its attached using thermal pads on the rear of the board.
    I've got some citrus-based TIM cleaner to hand and am contemplating giving it a good spray of that but not sure if its wise. Otherwise I guess I'll heat it up with a hair drier and give it another go. Advice as to whether the TIM cleaner is a good plan or any other bright ideas would be much appreciated.
    Cheers
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Since you're returning the motherboard just use a hairdryer to warm up the pads! When installing a backplate I never use the sticky pads, as long as the padding is there then screwing the heatsink in would be enough to hold it firm.
  3. Deadpunkdave
    9 May 2009
    The hair drier was taking a bit long so I ended up putting the board under the grill for a couple of minutes. Came off quite easily after that.
  4. Blogins
    3 Aug 2010
    Nice! Just so long as no capacitors fell off to arouse suspicions when it's returned! :D
