Modding Remove ram heatsinks
Discussion in 'Modding' started by notatoad, 16 Jun 2010.
  1. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i've got some ram with heatsink fins extending about 3/4" above the top of the ram, and now i want to put it under a low profile heatsink. problem is the heatsinks are glued to the ram. is there any way to remove the heatsinks without ripping the ram chips off, or do i just have to trim them down while they're attached?
  2. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    Use a heatgun, but do not exceed 100 C.
  3. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Dump the entire RAM DIMM in 92%+ Alcohol. That's worked for me in most cases as most of them are using tape/pads. They come off in ~30 minutes after soaking.
  4. notatoad
    25 Jun 2004
    the heatgun sounds scary, i'm trying alcohol now. thanks.
  5. Unicorn
    25 Jul 2006
    Why should the heat gun sound scary? Hairdryer will work as well. Heat them up and gently pull them off. I've done it on hundreds of RAM modules in the past and never damaged one.
  6. Shadow703793
    5 May 2009
    ^ I don't know.... I just don't like any of my PC components reaching near 75C..... :p
  7. capnPedro
    11 Apr 2007
    75*C... jeez GPUs get hotter than that in normal operation. :lol:
  8. Shadow703793
    5 May 2009
    Hence why I water cool GPU and CPU. :hip:
  9. Unicorn
    25 Jul 2006
    And why - no offence intended - you clearly have no idea what temeratures electronic components are capable of withstanding whilst powered down. SMT components and the boards they are mounted on are subjected to high temperatures when they are pre heated prior to being gas convection soldered at somewhere in the region of 600-650°F (315-350°C) and you're worried about 75°C. Your worry is at best, a little ill placed mate.
  10. lmth
    lmth What's a Dremel?
    29 Jun 2010
    Yes, I did it under hairdryer about 15min, and it came off.
  11. Shadow703793
    5 May 2009
    Completely agree. Yes, the RAM chips/PCB are capable to being heated to quite high temps. And yes I'm paranoid :lol: . Seriously. I can't stand anything above 68-70C. I know my CPU,etc can withstand above 75C but again, I like to keep everything cool. Trying to do phase change soon, for below ambient temps :D.
  12. *brian*
    *brian* What's a Dremel?
    23 Jul 2010
    I get scared when mine goes above 65 when folding! Once I forgot to turn my fans up and my GPUs hit 100 :(
