Motors removing a car cd player?
Discussion in 'General' started by SeT, 28 Aug 2006.
  1. SeT
    SeT What's a Dremel?
    7 Oct 2003
    My car(2002 kia spectra) was totaled about a week ago(just declared total friday) and I need to get the cd player out of it. Problem here is I didn't install it, nor have I ever installed a cd player in a car. I've googled and most of what I've found so far is "buy this manual" or "Buy such and such tool." The stuff is fairly cheap but I don't have that kind of time as the car is set to be taken to salvage tomorrow. If anyone has any tips/tricks on how to to yank the cd player, it would be greatly appreciated.
  2. Pookeyhead
    30 Jan 2004
    Is it original equipment fitting? If so, does it form part of teh dash, or is it just a single stand alone unit from an aftermarket manufacturer?
    The vast majority of head units require a tool to remove them. These are usually a U shaped clip that slots into two holes or slots on each side of the head unit. This releases catches on each side and the unit should slide forward enough to remove the cables.
    Most car accessory stores will sell them. Without this you'll probably have to damage either the head unit, or dash to get it out.
    I'm also moving this to the motors section, as it's more auto related than strictly audio related.
  3. SeT
    7 Oct 2003
    it's just a single aftermarket cd player.
    Is there anything that can be used in place of the tool? As it is I'm going to have about 15 minutes to get the cd player out. Any stops to find a tool would mean the body shop is closed when I get there and the car is gone in the morning.
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    best trick, get yourself a philips scerw driver, and start taking all of the screws out of the dash panels...
    pry panels away from metal dash frame (most just lock into place with plastic tabs)
    work your way until you can see underside of radio area... normally most radios (after market and stock) in foreign cars are held in by 2 screws either on the side of the radio, or underside...
    unscrew, pull out to point where you can get at wiring harness, remove
    also you should disconnect battery before you start
    total time invested... 25 minutes probably depends on how quick you are..
    screw guns help, battery can be left if you're careful
  5. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Different head units use different tools. A lot of them have 2 holes at either end like this:
    Code:
    |o                    o|
    |o                    o|
    For those, get a wire coat hanger and cut 2 pieces about 6-8 inches long each. Bend them into U shapes so that you can put one piece of wire in the left holes and one in the right holes. Then you basically push some clips inside the holes in towards the middle of the headunit and pull the whole thing forward. It takes a bit of wiggling to get the clips pushed but it should only take a few minutes.
  6. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    I used two breadknifes to get mine out! :p
    Not joking.
  7. Glider
    Glider /dev/null
    2 Aug 2005
    Since the car is totaled... Acetylene tortch ;) (not quite, but you get the point... Don't spare the dash...)
  8. finboz
    finboz What's a Dremel?
    11 Aug 2004
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    There's sometimes a single nut to remove round the back or some other fixing screw, the most awkward bit in some cars. You may get exact instructions with a bit of googling, even a pdf of the manual which should explain with pics.
    Here's an example I found for the daughter's ICE, fairly typical.
  10. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    If the car is totaled then all you have to worry about is hurting the deck itself and not the car then go to town on the dash. So, uh, ya own a chainsaw? :D
    I would reccomend a small toolbox, a hammer, and a crowbar.
