Other Removing Bit Tech Posts
Discussion in 'General' started by User-sam, 29 Jun 2011.
  1. User-sam
    User-sam When in doubt, follow your nose.
    10 Apr 2010
    Was wondering if it is at all possible to remove posts that you make on bit tech, bit of a mediocre to say the least in the forum area.
    Many Thanks
  2. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Nope, can only edit them. Obviously Mods can get rid if they so wish.
  3. User-sam
    10 Apr 2010
    My apologies I meant a thread I had made not an post.
  4. User-sam
    10 Apr 2010
    Where can I find the edit option for posts/threads, thanks
  5. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Again no but you can edit the title. If you've messed something up just change it to "ignore" or something, but then everyone will look and post on it and humiliate you... or something.
  6. SpaceBaby
    SpaceBaby AKA: Stophon
    1 Aug 2008
    again no, you can eddit said thread but not delete, an admin/mod can do it though
    User-sam likes this.
  7. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Editing posts there should just be an "Edit" button at the bottom right of each post" and if you do that then "Go Advanced" in the original post of the thread you can edit the title.
  8. User-sam
    10 Apr 2010
    Many Thanks for the help +REP to the both of you.
  9. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Not a problem chap, not a problem.
  10. Guest-16
    Guest-16 Guest
    Q: Why do people do this? When I was mod I got about 2-3 requests a year but I couldn't work out why.
  11. Krikkit
    21 Jan 2003
    I think he just means removing a thread Bindi, not all his posts... Could be wrong of course.
    User-sam: PM a mod if you want something doing. :)
  12. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Ex Girlfriends? Online Stalkers?
  13. User-sam
    10 Apr 2010
    Just wanted to edit a thread, not remove all my threads :) and online stalkers.. I would be so lucky ;p once again thank you very much for the help.
