Electronics Removing components from a motherboard.
Discussion in 'Modding' started by Digitalblueshift, 9 Dec 2004.
  1. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    I have a couple of old S370/slot1 motherboards and wI was looking at them longingly. The traces uderneath the laquer form a really cool lookiong design with all of the spidering and shapes they make, sort of an organic-mechanical thing. Im not sure where I want to put them, perhaps frame them and hang them over my desk.
    What I wanted to do was remove all of the components, ZIF socket, PCI slots, capacitors, ports, etc. Basically anything witha a solder point that extends past the board's back surface, (A few SMD's wont really bother me, just the really tall stuff) And I was trying to figure out how to remove it all without damaging the laquer and traces.
    I came up with a few ideas:
    One by one (NO!, too tme consuming)
    Bake it in the oven, (damage the oven, laquer)
    Iron it with a cloth over it (no steam) This seems the best choice as the heat will go right to the solder points and stick to the cloth without damaging the laquer much.
    Heatgun?
    Any suggestions?
  2. jgrade
    jgrade What's a Dremel?
    2 Mar 2004
    Don't quote me on this, but I have heard using a non-stick griddle or warming tray on low heat. You are sure to ruin the griddle but it may work.
  3. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    Hmmm - the only method I've tried with removing really large thinks from PCBs is a blowtorch - and that works quite well, though it burns the PCB.
    I'd try a very hot heatgun if you want to save your pcb.
  4. Herbicide
    Herbicide Lurktacular
    27 May 2004
    You could try twisting the capacitors off, and a dremel for the ports/slots.
    - H.
  5. Explicit
    Explicit What's a Dremel?
    23 Dec 2002
    Herbicide, that's rediculous, and ghetto.
  6. Krikkit
    21 Jan 2003
    To be honest, i agree with Herbicide - anything else will simply knacker the laquer on the PCB.
  7. Herbicide
    27 May 2004
    Another idea - drill the holes with a Dremel or other small bit drill. This still leaves the problem of the solder spots on the underside, unless they'd be OK, you know, adding a bit of character.
    - H.
  8. Rod10k
    Rod10k What's a Dremel?
    2 Jun 2001
    The way that electonic repairs are done on things like motherboards are using very small, very hot air guns. The nozzel is about 0.5cm across and they work like a non contact soldering iron. Not sure if your normal hot air gun is hot enough but got to be worth a try...
    Rod
  9. nohope4me
    nohope4me What's a Dremel?
    2 Jun 2004
    Could you get your hands on an SMD hot-air pencil?
  10. Rod10k
    2 Jun 2001
    I think that is probably what I was describing...
    Rod
